Alignment Question
I have been running -1 front 0 toe and -2 rear with 1/8 total toe in and Advan Neovas. I was pretty happy with the alignment except for a bit of pushing. I currently put on NT-01, first set of R compound and wanted to see do I need to do anything different as far as R compounds go and alignment.
Track/Occ. Weekend drive car only.
Thanks
Thanks
More camber!!
Max out the front as long as you can stay over 6 with the castor and try -3 in the rear and I personally would lose a bit of the toe but if that's what makes you comfortable than stay with it.
How much toe should I run. Running less toe would bring the rear around bit more easily, even with -3 camber ? I guess that is a question.
I was planning on running 1/4 inch total. (1/8 per side) I am lowered on Tein SRC.
I got my alignment done the other day. Got -2.25 in front and -2.25 with 0.28 deg toein total in the rear with 16k springs.
I see posts on here where some say that you need a camber stagger of -0.5 to -1.0 with more in the rear. Others say more in the front.
With a staggered set up do you guys think that alignment setup is good for the track.......Going to test it out next month. I am happy with the front, but thinking I need more in the rear.
Thanks for the input!!!!
Thateguhate
Feb 6, 2014 02:21 PM
