Alignment Setting?
Rob - your alignment sounds good... right on the mark. You might want to try different tire pressures to get the car a little more stable. My teammate, Brad (soloiiracer) had good success on Kumhos at 38f/34r pressure. By doing this, you tune a little front grip out of the car, and add a little rear grip making the car more stable.
Even with the Hoosiers and the big front bar (BFB) we are running 44f/38r to get the balance we want.
As for slight alignment tweaks from Rob's settings, try a slight bit of toe-out in the front to aid turn-in. We are running about 1/16" toe-out in the front, and about twice the toe-in as Rob in the back for stability. That's right, we have about 1/4" or .250 toe-in for the rear. It works! (just eats up tires)
news2kroller
Nov 3, 2005 10:44 PM
