Alignment Setting?
Old Mar 18, 2001 | 06:31 PM
Mack's Avatar
I've done a search with reference to this and found several threads. Set ups seem to vary so I thought Id post here for info on the optimum AutoX settings!
Thanks!
Old Mar 18, 2001 | 08:18 PM
robj's Avatar
I
Old Mar 18, 2001 | 09:20 PM
Jason Saini's Avatar
Rob - your alignment sounds good... right on the mark. You might want to try different tire pressures to get the car a little more stable. My teammate, Brad (soloiiracer) had good success on Kumhos at 38f/34r pressure. By doing this, you tune a little front grip out of the car, and add a little rear grip making the car more stable.
Even with the Hoosiers and the big front bar (BFB) we are running 44f/38r to get the balance we want.
As for slight alignment tweaks from Rob's settings, try a slight bit of toe-out in the front to aid turn-in. We are running about 1/16" toe-out in the front, and about twice the toe-in as Rob in the back for stability. That's right, we have about 1/4" or .250 toe-in for the rear. It works! (just eats up tires)
Old Mar 19, 2001 | 10:47 AM
Banannie's Avatar
we're running 35psi all the way around on Kumhos (and did when it was still "stock")
mball19
Apr 27, 2015 08:00 AM
news2kroller
Nov 3, 2005 10:44 PM
ceo2b
Apr 14, 2003 04:29 PM
AG Y2K S2K
Sep 8, 2001 07:03 AM
cdelena
Nov 14, 2000 06:41 AM
