Alignment and setup questions
Originally Posted by berny2435' timestamp='1359733578' post='22307794
I was thinking of going with Zero toe all around and reducing caster to more around 5 to 5.5 to allow the wheel to recenter a little better.
*edit* - keep in mind that as your driving evolves, so too will your setup. If you want to keep autoxing competitively but do some HPDE here and there, Id keep your preferred autox setup and only change easy settings like sway bar settings and settings on your Club Sports. A good track alignment isn't goint to excel on track, and a good track alignment isnt going to excel at autox. The two disciplines just call for much different specs.
Maybe my caster was measured wrong at the last alignment but it was around 6.5 to 6.8 on the front and the alignment before that was an old school string method but I told them to give me as much caster as they could with -2.9 to -3 camber. Maybe I need to drive someones car with less caster to see if I like it. It doesn't seem to re-center very well where it is with my 255s or my DD setup with 215s. It's a tad better with the narrower tire as you'd expect. Maybe I'm just too new to the car.
Maybe my caster was measured wrong at the last alignment but it was around 6.5 to 6.8 on the front and the alignment before that was an old school string method but I told them to give me as much caster as they could with -2.9 to -3 camber. Maybe I need to drive someones car with less caster to see if I like it. It doesn't seem to re-center very well where it is with my 255s or my DD setup with 215s. It's a tad better with the narrower tire as you'd expect. Maybe I'm just to new to the car.
6.5 to 6.8 sounds about right. That's not out of the ordinary. My car was quite low with -3.5 camber up front to get to 8 degrees of caster. I'm sure a few things are bent up on my car too
I was plagued by understeer most of the season. I couldn't figure it out. Finally, talking to Aaron (cuonice) at the Winning Formula down in KY, we decided to try less caster and low and behold it fixed it. It always seemed the more steering angle the car had, the more it would push. Made a lot of sense once he brought it up. I hadn't even thought of it.
If science of speed measures my caster under 6, I'll bump it up around 7 if they can.
Ima tell them to shoot for -3 front, -2.7 rear, zero front toe, 1/8" in max rear and 7 caster.
still undecided on the tires but I guess the track is hard on the left tires. Push comes to shove, I guess I could swap sides and run them in the opposite direction.
this is all great info for me as well. i have stock bars with square 255 rs3's with ksport coils (bought the car with them) i set my alignment to -2* camber up front and -3* out back, with rear tow at 1/8'. car handled great at the glen last september. is there a reason you run less rear camber then front? my searching as brought me to thing it would push more with that set up.
im always looking for insightful set up info
This is why I advise everyone to not worry about settings when going to their first (or first few) track days. One setup that works for someone might not work for someone else due to skill level, driving style, etc. It's like asking someone what type of person you should marry when you haven't even dated anyone.
