ATTN: Robrob; String alignment calculator
Old Nov 6, 2014 | 08:42 AM
freetors's Avatar
Default ATTN: Robrob; String alignment calculator
Robrob,I wanted to PM this to you but I think your inbox is full.
I really like the idea of your string alignment calculator but the link to it on your website is broken. I have done quite a few string alignments before and setting up the strings parallel to the centerline is always the part that takes the longest, especially with an unknown track difference. If you don't mind, I would like to see the formulas used in your program so I can replicate it in Excel for personal use. I understand how you calculate the toe and toe angle, the thrust angle, and the angle between the chassis center line and strings, but it seems like all of these rely on having the strings already parallel with the the center line and equidistant side to side. It seems like you have track difference as an output in your program. I feel like you'd have to have that as an input in the program to accurately calculate everything else.
Thanks
Old Nov 12, 2014 | 06:25 AM
freetors's Avatar
bump
Old Nov 12, 2014 | 07:16 AM
ebdavis's Avatar
This calculator originated on a Subaru forum iirc. A Google search found it for me a few years ago.
The only way I have found to make it work now is to copy the code (html? I'm not very smart at the computers) from the original post and paste it onto "notepad" in your accessories. Then open up the browser and click and drag it in. Something about the code is missing I believe as it doesn't sum the tow or calculate thrust but it does still display the tow for you.
You will also want to copy the pic from either Robs page or the original because the pic that pops up in the clicked and dragged code is the "x" that pops up when a pic doesn't load and this pic has the description of what each blank should be filled in with. Like I said, not smart at the computers...
Old Nov 12, 2014 | 07:35 AM
ebdavis's Avatar
I guess after all that it would be just as easy to build it in excel.
Old Nov 12, 2014 | 03:01 PM
s2000ellier's Avatar
rob's algorithm on his website
http://robrobinette.com/ConvertToeInchesToDegrees.htm
Code:
<script LANGUAGE="JavaScript">
function calculate() {
  document.input.toe_angle.value=Math.atan((document.input.inch_toe.value) / (document.input.tire_diameter.value))*180/Math.PI;
  document.input.single_toe_angle.value=(document.input.toe_angle.value/2)
</script>
Old Nov 13, 2014 | 03:37 AM
ebdavis's Avatar
http://forums.nasioc.com/forums/show...093484&page=11
Old Nov 25, 2014 | 01:00 PM
freetors's Avatar
Would there be any interest from the community for a step by step alignment program? The program would be capable of calculating camber, caster, and toe using simple methods like the strings, rulers, and levels. Of course, the accuracy of the results would only be limited by how meticulous the user is with their setup and measurements.
Old Nov 26, 2014 | 08:52 AM
imstimpy's Avatar
Am I missing something here or is the calculator converting toe from inches to degrees and has nothing to do with the centerline?
Old Nov 26, 2014 | 09:09 AM
Dead Serious's Avatar
I just use a trig calculator... http://www.carbidedepot.com/formulas-trigright.asp
Caster is a little tricky so some thing for that may be useful.
ab_sherm
Oct 6, 2017 04:00 PM
freetors
Apr 17, 2016 04:51 PM
blacktie
Apr 14, 2009 03:55 AM
chris2002
Apr 24, 2007 06:38 PM
s-duces
Apr 11, 2003 11:03 PM
