Autocross question
Old Jul 4, 2007 | 02:33 PM
prelupino's Avatar
Default Autocross question
I'm completely stock except with a catback exhaust.
Old Jul 4, 2007 | 03:14 PM
IkeWS6's Avatar
Google is your friend!
According to http://www.moutons.org/sccasolo/ you are in A Stock:
Stock
As a rough guide, if your car has modifications beyond this list it is not eligible for Stock Category:
* Anything available on the exact model and year of your car as standard or optional equipment, as installed on the factory assembly line (nothing available only dealer-installed is allowed), plus
* Standard OEM identical replacement parts
* Accessories, gauges, appearance, comfort, and convenience items (not replacement driver's seat, though) that basically don't help
* Added roll bar or roll cage to spec (not required, though)
* Driver harness (no cutting seats to install, though)
* Trailer hitch and/or tow bar mountings
* Any wheel of diameter and width identical to a stock or factory optional wheel, offset within +- 0.25 inch
* Most street legal tires that will fit the mounted wheels and stock bodywork
* Any shock absorber of the same type and mounting as original; no change to standard spring mountings is allowed; suspension geometry may not be altered; gas or hydraulic shocks are permitted
* Any brake linings; pre-1992 cars may use solid/braided metal brake lines.
* Any front anti-roll bar (no change to stock/optional rear anti-roll bar, if present)
* Manufacturer specified ignition settings only
* Any replacement air filter element (or removal of air filter element); no plumbing changes, however
* Engine bored no more than .020"; no balancing or porting/polishing of head
* Replacement of any part of the exhaust system past the catalytic converter (if quiet)
* Any oil filter
* Added clutch scattershield
Old Jul 5, 2007 | 07:08 AM
CobraTi's Avatar
Correct, you're still in Stock Class (AS for our cars).
Cat-back is fine, along with front sway bar, r-compound tires, and shocks, not coilovers though. Those are the main things to do in the stock class, with the tires obviously having the biggest effect on going faster.
TWF
Apr 20, 2012 06:53 PM
Tel1sps
Sep 21, 2005 11:09 AM
Swiftvision
Mar 20, 2004 07:53 PM
AutoAviat
Dec 4, 2003 10:37 AM
s2k_9000rpm
Aug 19, 2003 09:29 AM
