Autocross Tire Pressure
What is everyone running as far as tire pressure in autocross. I feel like I am running a little bit too high of pressure but who knows. Also information like cold/hot temp, surface, size tire, and how hot the day was would be helpful. I am running stock sized Hankooks on an ap2 with stock shocks if that makes a difference also.
Factory AP1 sized RE-01R
Cold pressures:
29-30 R
32 F
My experience with the RS2's is that they aren't that great and very fidgety with temp. I think we ran 36F 34R cold or even as low as 34/32 in 225/245 sizes with front bar.
Cold pressures:
29-30 R
32 F
I had Hankook RS2's on my Enkeis. From my experience, Higher pressures on street tires always seemed to work better for me. I had 225/45/17's, 245/40/17's and IIRC front tire pressure was 42 and rears were 40. I tried lowering the pressures, but it seemed to slide around alot more. Usually the surface temperature was pretty hot and most were hot days, some where in the 90+.
On my crappy Toyo T1Rs I run 33F/31R. AP1 wheels, 205/245. Also running Tein RAs. I forget what they're set at. 6 clicks from full-hard front & 10 clicks rear, I think. UK spec alignment.
Still a little loose, but much better than when I first put these tires on and was running much higher pressures, and equal settings on the Teins.
Originally Posted by jguerdat,Oct 5 2007, 03:06 PM
When I ran the RE01Rs last year in the local Road Tire class, I used the same pressures as the S02s - 36f/32r. Worked pretty damn good...
