BASE TRACK SETUP
Old Mar 20, 2012 | 05:32 PM
labala's Avatar
Default BASE TRACK SETUP
Hello guys, need some help... i have a AP2 here in the dominican republic. i bought some ohlins shocks from performance shock in california PSI. This is a track car and i would like to know form you experience with this car, what would be the initial or base start up suspension wise. Cambers; toe etc... Our track is not a fast track, but has some tight curves.
thanks for your help!!
Old Mar 20, 2012 | 07:25 PM
macr88's Avatar
Are they TTX's? If so just post in here
https://www.s2ki.com/s2000/topic/830.../page__st__200
Old Mar 20, 2012 | 09:15 PM
c32b's Avatar
big money setup
Old Mar 20, 2012 | 09:47 PM
macr88's Avatar
It all depends on how you look at it, I've gone through like 6 different suspensions on my Camry so I look at it like this, you either pay now and enjoy something good or continue paying for crap. Fortunately there's more than just crap for the S unlike the Camry.
Old Mar 21, 2012 | 01:39 AM
c32b's Avatar
i just wish i could put down the coin for that!
Old Mar 21, 2012 | 05:22 AM
macr88's Avatar
Why can't you?
Old Mar 22, 2012 | 05:26 PM
labala's Avatar
Ok guys, thanks for the input. the suspensions are Front TTX40 2 way upgraded to a 3 way moving the HSR adjusters from the rear 4 way TTXNH04, converting the rears into a three way also. this because we are not permited to use reservoirs down here. Rules...
Thanks again
Old Mar 22, 2012 | 06:48 PM
macr88's Avatar
Base blind setup without knowing anything about how the car is setup.
2.5° camber front and rear
0 toe front
Caster, some say max caster but I just run 5.5-6°
1/16" total toe rear
What spring rate you running?
Old Mar 23, 2012 | 01:38 PM
Beau@Performance Shock, Inc.'s Avatar
Thanks again
Christian,
We used through rod TTX40 (which come standard as a 4-way), and moved the HSR adjusters to the front giving you a 3-way set at all four corners (LSC/LSR/HSC). We were pretty stoked with the way that they turned out!
blueosprey90
582
Jan 25, 2018 02:55 PM
8kGoodENuff
Jul 8, 2014 05:51 AM
jhonnyboy
Mar 28, 2013 03:21 AM
Mr.Integra
May 3, 2006 06:32 PM
