Basic How To Build an S2000 Racecar
This is what I ended up doing for the catch can:
I eliminated the PCV valve by capping both ends. I put a catch can with a breather filter on the large vacuum line from the front of the valve cover.
An update on the catch can shown in the pic above. I ran an open practice with the pcv valve capped and the Greddy oil catch can attached to the large front vent hose. I had zero issues with blue oil smoke and my oil level didn't change at all after an hour and five minutes on track. The catch can had very little oil in it. It is the pcv valve line that is causing the blue smoke and drop in oil level on our cars.
I tried a variation on this setup at Infineon yesterday and it caused the dipstick to blow out and oiled my engine bay. Ugh.
Instead of capping the PCV, I capped the large vent hose at the front of the block and instead routed a line from the PCV to the catch can and added a breather filter to the catch can.
I'm wondering abut the "Krank Vents" http://www.et-performance.com/normal.html.
Has anyone tried these as a solution?
The manufacturer says:
These solve the problem and still maintain crank case ventilation. Small Krank Vent goes in the small hose between the OEM PCV and and the intake. The large one goes in the other larger hose. They say you can use a catch can on the hose from the large port at the front of the valve cover if you want. This system creates negative pressure/vacume in the crank case so no more oil getting sucked out and no need for catch can.
