Battle Aero Chassis mount wing
So i ended up just selling my J's type 1 wing, I was looking for a more rigid and larger wing when i came across Battle Aero. Click Here!!!!!!!!!!!!!!!!! Has any one used their wings? It looks like a very nice setup and chassis mount looks perfect for what i want. Ive just never heard of them. What do you guys think?
If you're looking for more rigid mounting, why not fab your own stands, and mount to the floor, through the trunk. You could then attach whichever wing design you wanted (Voltex, apr, etc). Or, if you want something more plug and play, maybe something proven from Good Aero.
In any case, the wing design (drag vs downforce) is probably more important than the mounting method. I would tend to stick with proven wings vs someone new, unless they could show me independent testing to validate their design
I do not recommend that wing. There is a local S2k owner that has the wing installed on his car and it wobbled like crazy when I pushed on it slightly. The wing was running just that threaded rod, I think they might of resolved it with the cross bracing....
ended up just buying the mount and then i will be buying a wing element from a reputable aero company. Any recommendations on what wing to put on it? Ill be adding some cross braces to make the mount super solid. I have look at the APR GTC 300, but what else is out there??
Please update with pictures when you finish adding on the cross braces.
