BBK heat sheilds
I have just fitted a 330mm BBK and found my studs arn't long enough when I have my spacers and wheels fitted
, anyway different story.
When I fitted the BBK I removed the heat sheild from the car. The rotors are about 8mm away from the rod end rubber boot/cover. There is also the ABS sensor which is close by!
Is this going to be a problem? When on the track will the generated heat from the rotors melt them?
Any advice is welcome, thanks
, anyway different story. When I fitted the BBK I removed the heat sheild from the car. The rotors are about 8mm away from the rod end rubber boot/cover. There is also the ABS sensor which is close by!
Originally Posted by Voodoo_S2K,Sep 28 2009, 10:57 PM
I just trimmed off the minimal need to clear my Endless brackets, so the shield still covers all of the ball joints.
carlossantana
Jul 19, 2013 05:25 AM
