Best supercharger setup for the track.
#31
#34
#35
SOS Kit. The main issue is heat soak. I have V mounted my Heat Exchanger and Oil cooler so still get air flow to the Rad (Ian's or now Sake bomb) and have a brake duct from the headlight ducting fresh air to he filter. It will be cool, if you keep it be cool. Proper cooling will make it work great
s2000ellier (11-05-2018)
#36
PTuning appears to be doing a new batch of their turbo for the S2000. While I don't like their specific choice of turbo (the older Garretts). In many ways it is similar to the SOS turbo. However, I think they have a better manifold design. SOS uses an internal wastegate, Ptuning uses an external. SOS uses a twin-scroll turbo, Ptuning appears to use a V-band mount.
Both tuck the turbo under the manifold directing heat out of the engine bay. With both, battery and fusebox remains in place. Both merge the wastegate into the exhaust.
https://www.s2ki.com/forums/s2000-fo...order-1188441/
https://www.scienceofspeed.com/index...0-2000-05.html
My turbo preference would be for a manifold twin scroll (like SOS), equal length manifold (like PTuning) using a BW EFR turbo with an internal wastegate, internal BOV, and 3-port boost solenoid included on the housing. The EFR, like the GT/GTX turbos in these kits, is a bit dated. But they still have among the fastest spools because of their lightweight turbine impeller and don't require any external wastegate or BOV plumbing. Unlike the Garrett IWG that SOS uses, the EFR exhausts to the same V-band exit as the exhaust. However, no one makes a manifold for that combo let alone a complete kit.
A centrifugal supercharger is not the same as a turbo, although the compressors look similar. In the turbo, the compressor will run at a constant speed for a given pressure ratio, in the centrifugal turbo that varies. The volume in a twin screw (like Sprintex)or updated Roots supercharger (like the newer Eaton TVS) linearly increase volume with speed/ Doesn't the centrifugal vary as the square of speed?
Note that adding a serious power adder increases wear and tear, especially on the brakes that will be used for longer periods and more often reaching higher temps. I'm unclear how it makes a more enjoyable track day compared to a more sophisticated suspension (e.g. Wisefab), fender mods to fit 285/30-18 RE71r tires, 295/30-18, 315/30-18, or 335/30-18 tires, and ITB intake, etc.
#37
#38
Wouldn't coming out of the turns faster count for more than a few mph at the end of a few straights? Even for passing, does a centrifugal supercharger really do it? A positive displacement supercharger or turbocharger would have a much fatter power curve.
However, there are no positive displacement superchargers for the S2000. They exist for an FWD K-series. Z06 and ZR-1 Corvettes have them. The Dodge Hellcat and Mustang GT-500 also. There are some great kits from Sprintex for the FT86 that incorporate a Laminova tube intercooler.
If you look at the SOS HP graphs of the centrifugal supercharger and their turbo, they tell the story. Both are about 365 hp at 8000rpm. The turbo is about 315hp at 6000rpm, the supercharger about 245hp. Same price.
If SOS is using a T4 flange on their turbo manifold, it could be used with an IWG BW EFR. You would need a new downpipe, but relatively simple with a straight V-band to the turbo and no wastegate downpipe. On the compressor side the BOV is built in. The new G series from Garrett also is supposed to have an IWG with single V-band outlet. But...I don't think they have any T4 or T3 twin scrolls.
#39
I haven't dyno'd mine yet but thinking there was some whitchcraft used on the Evasive setup as Ive yet to see 10 psi. 7-8 which translates to about 310whp I think
Will be back modding the car in a few weeks. Have already repositioned the oil reservoir. Will be updating my info soon but if I was to start over I think SoS
#40
Why did the HKS not make your short list?
