Best sway bars
I was wondering if anyone could help me out with this since I've searched and not really gotten what I was looking for. I need to know which sway bars would be the best for my type of driving. I drive very aggressively through fairly tight mountain roads with a lot of switch-back corners and an occasional long sweeping corner or two here and there. I've been looking at the Cusco bars, but wanted to see if anyone had a better preference or suggestion.
Thanks!
-Ben
Thanks!
-Ben
ohhh boy.....people on this forum will not comment on questions as such for prep your car.....the answer will always be save your money, spend it on track time and then see what you need changed.....the sway bars on these cars don't need to be touched in fact some remove the rear....
^ Now you're going to get even better responses. Public roads are not intended for "pushing the car for everything it's worth". Take it to the track if you want to push the car. And when you get to the track, then you can start asking for setup info. Otherwise, you'll have better luck in "S2000 Talk".
