Black TR C3s on GPW CR
Old Aug 2, 2010 | 09:02 AM
Z06phile's Avatar
[QUOTE=TubeDriver,Aug 2 2010, 07:54 AM]The OEM black Honda lugs are not the correct lug for aftermarket wheels.
Old Aug 2, 2010 | 09:08 AM
Z06phile's Avatar
Originally Posted by patinum,Aug 2 2010, 08:38 AM
I got the same set of wheels (2 sets actually). My front center rings didn't it right? Do they work on yours?
Like too small?
Old Aug 2, 2010 | 09:33 AM
patinum's Avatar
Originally Posted by Z06phile,Aug 2 2010, 11:08 AM
Like too small?
Yup. Inside diameter seems slightly small.
Old Aug 2, 2010 | 11:01 AM
Orthonormal's Avatar
I'll back up the statement that Honda lug nuts are ball-seat type and most aftermarket wheels are conical-seat. One notable exception is the TR Motorsports stock-sized wheels for the AP2, which have the same size, offset, center bore, and lug nut seat as the stock wheels.
"Acorn" I believe refers to the shape of the top of the nut, indicating a nut with a closed, rounded top like the stock lug nuts, as opposed to an "open" nut where the stud sticks through.
Old Aug 4, 2010 | 04:26 AM
Z06phile's Avatar
I rotated them last night. The front rings are a little tight on the hubs... had to work to get the wheels off. I removed the rings and took extra care to center the wheels before torquing them down.
Old Aug 4, 2010 | 04:34 AM
Z06phile's Avatar
When I pulled the wheels, I could see where the Honda lugs took the paint off and you definitely give up some contact are by using them. I reinstalled them with some black aftermarket cone-seat lugs.
Old Aug 4, 2010 | 06:25 AM
Bikey's Avatar
Thanks Orthonormal - I compared the lugs that ship with the TRs to the stock lugs and the seat area and angle looked identical. And looking at the wheel, the lug seat area appears to be the same as the OEMs
I also compared the TR lugs to "tuner" lugs and although the cone is deeper on the tuner, the cone only touches the wheel on the lower portion (tuner lugs were mounted on a Volk wheel, and the seat area marks were approx the same length as the seating area on a stock lug).
Old Aug 4, 2010 | 07:57 AM
The stock lug nuts don't really have an "angle", the mating surface is round when viewed from the side.
Conical seat lug nuts have a mating surface that looks like a straight line when viewed from the side.
CHILIBEANZ
Jun 9, 2016 03:03 PM
silence808
Oct 1, 2010 11:34 PM
kingfai
Sep 24, 2009 08:15 PM
ilikecereal
Mar 17, 2009 10:16 AM
