Body Rigidity
Old Jul 31, 2010 | 11:24 AM
  #21
INTJ's Avatar
Space bus
Old Jul 31, 2010 | 12:19 PM
  #22
spets's Avatar
I'm pretty sure he means vertical G's, aka going over potholes and such.
Old Aug 1, 2010 | 04:50 AM
  #23
captain_pants's Avatar
Confirmed, 11G vertical spike over pavement 'irregularities'. We're only sustaining 4G lateral in turns.
Old Aug 1, 2010 | 11:34 PM
  #24
EssToOfouzEn's Avatar
very interesting topic.. so far I'm getting to understand how the concept works but my question is how will this matter take affect on non-forged materials vs forged materials, steel for instance. since the mass of a forged item will be greater than a non forged. Also, I'm pretty sure Honda used top of the line materials to make an open top car THIS rigid.
Old Aug 2, 2010 | 03:04 AM
  #25
ZDan's Avatar
Density of forged steel is pretty much the same as cast or rolled or whatever other process, ~0.283 lb/in^3, forged parts aren't more massive. Modulus of elasticity (i.e., stiffness) is also the same, ~29x10^6 psi. Strength properties of steel will, however, vary greatly depending on alloy, temper, and forming process.
What gives the S2000's steel frame its stiffness is the design/shape/layout, not what kind of steel was used.
Old Aug 2, 2010 | 07:44 AM
  #26
User 121020's Avatar
Bingo. ZDan is exactly correct. It's the cross-sectional dimensions that dictate the stiffness of the S2k chassis. Features like the tall transmission tunnel increase the front to rear bending stiffness.
Good discussion, everyone.
Old Aug 2, 2010 | 10:24 AM
  #27
ace123's Avatar
Also, to generalize, forged parts usually have longer fatigue lives than cast parts. A lot if this is due to the surface; forged parts typically will have compressive residual surface stresses and a smooth surface. The improvement in fatigue life/performance is thought to be because precracks are harder to form in a smooth surface with compressive residual stresses when compared to precrack formation in a rough, discontinuous surface that may have tensile residual stresses.
The longer fatigue life can also be traded for performance: the better part could instead have an equal fatigue life with slightly increased loads. But with metal fatigue, a load increase on the order of 10% might cut the predicted mean lifespan by a factor on the order of 2.
But again, that's strength, not rigidity.
OTOH, composites will lose rigidity as they fatigue. Typically carbon FRP loses on the order of 10% of its modulus before total failure. This is because during fatigue, fibers are broken and no longer transfer loads.
slickfast
Mar 8, 2019 07:16 PM
ruexp67
Jun 24, 2016 07:21 PM
Jimmy Roadster
Dec 12, 2009 07:10 AM
