Boots for shock piston rods
Old Jan 1, 2013 | 02:34 PM
99SH's Avatar
Default Boots for shock piston rods
After 4 years of use, I dropped off my Tein SRCs to their HQ office for an overhaul. The Tein techs noted that all 4 piston rods had scoring and pitting damage which need replacing at $65 a pop. I'm suspecting rocks and debris may have been trapped around the rod/housing area causing some damage over the years.
Now the SRCs don't come with any suspension boots (gators), but thinking about running some before I reinstall the coilovers. Wanted to hear if anyone runs boots over their rods and if there's something they can recommend.
thanks
Old Jan 1, 2013 | 05:39 PM
robrob's Avatar
KW V3s come with a rubber "skirt" that hangs down from the bump stop. The bump stop itself also covers a lot of piston rod. The KW system seems to work for a one inch lowered car because I recently pulled a shock and the piston rod looks pristine with absolutely no oil leakage. If you're not lowered then you've got an extra 0.7" of piston rod exposed.
Here's a pic of my left rear under normal compression. You can see the "skirt" inside the coils:
Old Jan 3, 2013 | 08:49 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
One word for you guys. Shockwears.
They cover the entire shock, velcro on. Brilliant product I have used for years.
Old Jan 3, 2013 | 12:59 PM
99SH's Avatar
Cool product, thanks for the tip
Pricey, but will likely go with these.
Old Jan 3, 2013 | 01:08 PM
BuggyofMildDiscomfort's Avatar
We never run anything over the shocks for the safari buggies, just tends to hold the shit against the shafts...
Old Jan 3, 2013 | 02:56 PM
robrob's Avatar
I wouldn't recommend the full shock covers for track cars because the covers act as a blanket to prevent shock cooling.
Old Jan 3, 2013 | 03:14 PM
99SH's Avatar
From what I can see it only covers part of the damper body, springs and almost the entire rod. Since the reservoir is external the impacts are negligible. I take it that the shock cover extends the length of the upper & lower spring seats.
Unless I'm missing something?
Old Jan 3, 2013 | 03:40 PM
oinojo's Avatar
unless you are running a pillowball top mount, most shock shaft damage is striations from side shaft loading.
Old Jan 3, 2013 | 04:37 PM
CKit's Avatar
Does that apply to people who daily drive their shocks through salty winters or just race only use?
Old Jan 3, 2013 | 05:18 PM
macr88's Avatar
Add bad springs to the list as well as super tight pillowballs and incorrect bushing preload as far as items that can cause side loading.
Damage from a rock is definitely possible, I'm knocking on wood because I've been really lucky
