Brake bleeder?
Originally Posted by robinson,Apr 10 2007, 09:51 PM
I have the motive too...only takes like 5-10 mins after the wheels are off.
I also read that Motive improved that cap for our MC, so I'm wondering if there are any problems with the S2K MC cap and if I should pick up 2 additional clamps to make sure the top stays tight.
Originally Posted by Vitt,Apr 10 2007, 09:58 PM
I recently bought one, haven't used it yet. Do you guys with the Motive have any problems with losing pressure when using the Powerbleeder cap on the MC? Other Honda/Acura owners had problems with that in the past.
Originally Posted by robinson,Apr 10 2007, 11:10 PM
I've found that over tightening is the culprit of leaks. If it's too tight it will pull the sides down and bend the cap.
Originally Posted by mikegarrison,Apr 10 2007, 10:35 PM
Yes, but undertightening also does not work. It takes practice to get it just right.
and then in that time you just have to keep cleaning up the brake fluid going everywhere >_<
its not like its very easy to adjust either
Originally Posted by mikegarrison,Apr 11 2007, 01:29 AM
I mostly use it with no fluid, just air. I bleed out the brakes until the fluid comes out pretty clean, and then I just top off the master cylinder reservoir. No fluid spilled.
- thanks
