Brake bleeder?
Originally Posted by Conedodger,Apr 11 2007, 04:42 AM
Why not buy a second Honda MC cap and modify it to work with the power bleeder? I did that with a Fiat cap for my X1/9 and a different brand power bleeder and it worked well, no leaks.
Originally Posted by owenxguo,Apr 11 2007, 11:05 PM
what do you guys mean losing pressure?
Here is a pic of if
I've never used this before, so someone correct me if I left anything out.
BTW, I did a search on SpeedBleeders vs. EARLS Solo Bleed (in UTH forum) and it looks like the Earls is a bit better system, as it has less chance of leaking over time.
Having said that, I used Speedbleeders on my GSR for 4 years and never had any problems. Just be careful not to over tighten the things, because apparently that's what causes them to start leaking over time.
You are supposed to put brake fluid into the motive reservoir - I never do. Never had a problem or a mushy brake pedal, as long as you check your fluid level after bleeding a wheel and don't run it low, it should work fine. Basically you're just pressurizing the brake system.
As for attaching the PITA universal cap on, I saw someone use 2 of these at the track: Ratchet bar clamp. Brilliant! Quick, cheap and MUCH easier than the chain.
Originally Posted by rlaifatt,Apr 6 2007, 11:42 AM
I've always used speedbleeders with 100% success. Bleed brakes at just about every event for 5 years. Proper size for stock calipers is SB10125.
Originally Posted by Hobbs5313,Apr 14 2007, 09:59 PM
I just bought and installed speed bleeders on my car. Even though it came with thread sealant applied to them, I still got a small leak from two of the bleeders. It looks like the leak's coming from the thread area. I'm going to take them out tomorrow and apply more sealant and see if that fixes the leak.
Website instruction says "Screw in the Speed Bleeder
It looks like I fixed the leak. I took all four bleeders off the car even though only two of them leaked. I checked the original sealant and found the two leaking ones didn't seem to have enough of it. I then cleaned them with soapy water, dried them, brushed on more sealant and then dried them in the oven. No more leaks now.
Yep. I bled the brake fluid again after reinstallation. What's interesting is that even though I just put in ATE Blues, the brake fluid color that came out was the original light brown. I guess I should have kept flushing the brake fluid until it turned dark blue instead of light blue. I didn't have that issue with the front brakes though. Oh well.
