Brake Cooling Problem
Old May 7, 2008 | 07:23 AM
PrOsPeCt S's Avatar
Default Brake Cooling Problem
im currently running Carbotech XP10s all the way around with 2in brake ducts up front, i think the brake ducts are to small therefore not allowing the brakes to cool enough, there getting so hot to the point where i cant make a set of front rotors last more than 2 days.
can anyone help?
thanks
Rene
#107 s2000 TTC
Team BDR
Old May 7, 2008 | 07:32 AM
DER MotorSports's Avatar
have you considered adding booster fans in them to run during cool down laps and into the pits? may I assume you are venting them properly - into the center of the hub to work out through the vents - not to insult your intelligence I just don't know what you know. other than that you are going to have to straighten out the duct work for increased flow, find a way to stuff larger ducting hose, go 2 true piece rotor or go BBK. call to discuss if you want 770.631.6779
Old May 7, 2008 | 07:58 AM
PrOsPeCt S's Avatar
well i have the ducts pointed at the center of the rotor, just like my two other race cars, but the other cars both have 3in ducts. and i have never had any problems with them.
do the sell the fans to fit the RPF1s?
Old May 7, 2008 | 08:53 AM
crash's Avatar
dont brake so much?
I have cobalts on all 4 corners and mine last 4 or 5 races
pads and rotors...
o and I have not cooling ducts.
Old May 7, 2008 | 10:11 AM
PrOsPeCt S's Avatar
ok i also forgot to mention i live in miami and i can garuntee its no as hot on a track any where else other than here. and we havent even seen the start of summer months yet.
Old May 7, 2008 | 10:24 AM
raced at Sebring often in a 3300 pound car by rules with close to 380 HP on track temps 140 so yes, I know. The fans are sold by ducting diametre so it doesn't really matter. As you are a racer, you know how unusual this is for so lightweight and low powered an auto.is it possible your pads are dragging????? have you ever painted your calipre to at least see your peak temps or measured with even a laser pyrometre?
Old May 7, 2008 | 11:27 AM
PrOsPeCt S's Avatar
no i have not, never really looked into it.
Old May 7, 2008 | 11:47 AM
you going to roebling?
Old May 7, 2008 | 12:45 PM
Jaku's Avatar
do u have brake dust shield?
Old May 7, 2008 | 10:23 PM
PrOsPeCt S's Avatar
yes i will be @ roebling. will you be there?
