Brake Ducts (Almost) Finished
Old Mar 23, 2012 | 11:51 PM
Beard's Avatar
I like your idea.
I think you can improve flow a little better if you were to have a flat under tray (aluminum or plywood) and the do the same set up. You don't have to run it like a splitter, rather just make it flush with the OEM bumper profile and extend it back to the start of the "front axle" (free nasa tt mod). With this done, I feel like the airflow will be smoother underneath the front end and allow the ducts to be more efficient in catching the airflow.
Either way, id be interested in seeing some data with brake rotor temps on this setup.
Old Mar 24, 2012 | 04:13 PM
clarkster009's Avatar
You guys are really making me want to invest in a pyrometer to test them. Updated the pictures.
Old Mar 26, 2012 | 02:16 PM
Reapur's Avatar
Clarkster, where did you get the pressed aluminum flanges for the heat shield end of the hose?
Old Mar 26, 2012 | 03:25 PM
s2000ellier's Avatar
Me likey.
Old Mar 26, 2012 | 07:02 PM
http://www.aircraftspruce.com/catalo...uctflanges.php
I can't claim credit...got the idea from RobRob's site (www.robrobinette.com)
Old Mar 26, 2012 | 07:38 PM
markhs2's Avatar
Looks like a great idea. I'm interested to see the results.
One thing; wouldn't it be better to put the hole in the shield at the rotor as close to the center as possible. So the air flow goes into the center of the rotor and up through the vanes not against the rotors inside face only? Or is that as close as you can get?
What was the size ducting you used?
Old Mar 26, 2012 | 07:51 PM
That possibly may be more beneficial, but to be honest, those dust shields are a weird shape and the only flat part is right about where I cut, to mount the flange easily.
I used 2 1/2" ducting.
I followed Rob's tutorial: http://robrobinette.com/S2000BrakeDucts.htm. If you use 2 1/2" ducting you need to remove the air pump, or maybe modify the bracket at least as there is not much space for the hose.
Old Mar 26, 2012 | 08:06 PM
markhs2's Avatar
Do you think it's possible to run a brake duct and still be able to use an AEM V2 cold air intake?
The AEM places the end of the intake right up behind the bumper on the passenger side. It would really be nice if it would work to use them both together.
Old Mar 27, 2012 | 09:48 AM
I found this picture of the intake. It doesn't look as though there is room for the tubing with this intake, as you have to remember the tire is behind the liner so you have to run the tubing through the inside part closest to the radiator.
Old Mar 28, 2012 | 10:16 AM
The Reverend's Avatar
There is room with an AEM intake. I did it on my first S2000.
