Brake Fluid Boiling?
I will replace my pads this season. should i change the rotors too? Or do one at a time..to determine the problem. My tires were actually pritty new at the time...very little wear... now their worn... alittle uneven due to the number of sharp right turns at cayuga...(several track days there)
Yes they are OEM Pads and rotors... and original... but the pads still had some left on them...
Good call clag.
Im looking into some carbotech panther Plus pads... seem to suit my needs. Something to start with and work good for street too... Any suggestions?
Where to buy besides carbotech.com.... its not working right now
If your rotors have excessive wear, I would just replace everything and do it right the first time, then do a thorough flush of the system.
i just started tracking my car this past year. It looks like the rotors are OK but im going to pull the pads out and get a good look. I'm probably just going to change the rotors too so next time i go to the track i dont have problems.. I changed the fluid last year... but will probaby switch to ATE super blue.
If your rotors are not worn out, just change the pads for now.
Make sure you bed in the new pads, and see if the problem persists. From what you are describing, I don't think your rotors are "warped". Because if that is the case, you would be getting vibrations at even a low speed.
I am running the Hawk HP+, but you saw how loud noisy my brakes were last time at shannonville.
Good luck.
Good luck.
