Brake fluid, need quick answer
Old Mar 19, 2003 | 11:44 AM
Sev's Avatar
Sev
Default Brake fluid, need quick answer
Hi guys,
quick question, how much brake fluid will I need to fill the system in the s2k if I flush it and fill it up with Motul 5.1?
Thank you,
Old Mar 19, 2003 | 03:01 PM
Gloffer's Avatar
You can do it with less than 1 liter, if you're careful and stop bleeding individual brakes right when you start getting the new fluid at the bleed screw. But to be safe and in case you over-bleed, you should have 2 liters on hand. You'll want that extra liter for additions in the future anyway.
You should consider the ATE SuperBlue fluid. It's very easy to see when you've got the old fluid out when you swap between the stock fluid and SuperBlue and then back to the amber colored ATE fluid.
Old Mar 19, 2003 | 05:16 PM
jvils's Avatar
That's what I did. The ATE blue really makes it easy to see clean, clear fluid. Also, it was the first time I ever did it, so I gave quite a few pumps, just to be sure (7 or 8 after I had clear blue fluid). I basically used the whole liter, had a little bit left. If I need to bleed again, I'm sure I'll be opening the 2nd liter. Anyway, I'd get two, just in case.
Old Mar 21, 2003 | 11:55 AM
Bassem's Avatar
one liter is easy. just did this last weekend. using a quarter liter per caliper practically guarantees clean fluid.
bassem
Old Mar 22, 2003 | 07:12 AM
Legal Bill's Avatar
Out of curiosity...Why do you need to switch back to the amber? Is the blue inadequate for some street aplications?
Old Mar 22, 2003 | 07:29 AM
Prolene's Avatar
[QUOTE]Originally posted by Legal Bill
[B]Out of curiosity...Why do you need to switch back to the amber?
Old Mar 22, 2003 | 10:05 AM
Legal Bill's Avatar
[QUOTE]Originally posted by Prolene
[B] Except for color, amber and blue ATE have the same specifications.
Old Mar 22, 2003 | 10:15 AM
Tedster's Avatar
I've never had any problem doing a complete flush with a 1 liter bottle.
Old Mar 22, 2003 | 12:00 PM
Sev's Avatar
Sev
Thanks for all the info guys.
TheT0nemeister
Sep 3, 2010 06:58 AM
skool u
Nov 27, 2009 08:51 AM
myflys2k
May 25, 2009 06:44 PM
LubedKoala
Jul 21, 2007 03:17 PM
2QYK4U
Dec 1, 2006 06:05 PM
