Brake Pads
Old Apr 3, 2007 | 10:57 AM
krazik's Avatar
Administrator
the cobalts don't eat the rotors and they stop squealing (mostly) after about 3-4 days of using them on the street.
-Ry
Old Apr 3, 2007 | 11:11 AM
alejo's Avatar
-Ry
XP10's stop the noise after a day - dust remains high though.
Old Apr 3, 2007 | 11:16 AM
rlaifatt's Avatar
Originally Posted by wing,Apr 3 2007, 11:43 AM
rlaifatt, any reason you don't run HT-10's front and rear?
You don't need nearly as high-temp a pad for the rear (front's do most of the work). As msm_s2k said, you can get away with even OEM pads rear, but most recommend/use a pad that's one or two levels down from the front (and they're cheaper). I generally used HT-10 front with Blues of Blacks rear (no good reason for choosing between them).
Old Apr 3, 2007 | 12:07 PM
wing's Avatar
Makes sense, although I ran OEM front and rear last week at the track and both wore perfectly evenly to nothingness. Could be that once the front faded the rears took the brunt of the force though.
Old Apr 3, 2007 | 02:43 PM
RV6pilot's Avatar
Originally Posted by Pointblank,Apr 2 2007, 10:55 PM
I'm currently shopping for brake pads right now.
Trying to sneek in a set of pads after we already set a handicap for laguna?
I'm still ok with the handicap though....
Old Apr 3, 2007 | 03:22 PM
B.C.'s Avatar
Hey PUNK@SS:
You're dead:
https://www.s2ki.com/forums/index.php?showt...&#entry10186055
BC
Old Apr 3, 2007 | 03:45 PM
Pointblank's Avatar
[QUOTE=RV6pilot,Apr 3 2007, 03:43 PM] Trying to sneek in a set of pads after we already set a handicap for laguna?
Old Apr 3, 2007 | 03:48 PM
wing's Avatar
Bedding in process is explained well on Hawk's website.
Old Apr 3, 2007 | 05:25 PM
myflys2k's Avatar
Originally Posted by msm_s2k,Apr 3 2007, 12:39 PM
It's so easy to change pads, no reason to compromise. Run track pads for the track (Cobalt XBR2) and street pads for street.
Track pads dust and are noisy way too much, takes 10-15 min to change fronts.
Old Apr 3, 2007 | 10:36 PM
cthree's Avatar
Administrator
You might want to get some HP+ pads for the front to change into after so you don't have to change the rear pads after each event which really sucks. The fronts are easy after you've done it a couple of times. Go get a giant set of channel lock pliers like these from Home Depot:
http://www.channellock.com/acb/stores/1/48..._Tongu_P4C3.cfm
They aren't called BigAZZ for nothing. Wrap the jaws in electrical tape and you'll have a 2 second piston retractor (credit to davepk for that).
