Bros Wing
Old Jan 17, 2012 | 01:32 PM
patinum's Avatar
Default Bros Wing
Just saw this in the group buy section -
https://www.s2ki.com/s2000/topic/922...ned-for-s2000/
Thoughts? I'm pretty dumb when it comes to aero, so I was just going to get what seems popular (GTC-300). Pretty good price on this though.
Old Jan 17, 2012 | 02:15 PM
psychoazn's Avatar
GTC-200 and the Voltex wings are the really common ones.
I only know of 2 GTC-300 users
In terms of functionality, there's no question that the Bros wing will work. What's difficult to judge is the efficiency compared to the others out there (Voltex, Aeromotions, APR, etc.)
Old Jan 17, 2012 | 02:56 PM
CKit's Avatar
That bracket will totally destroy your trunklid at speed.
Old Jan 18, 2012 | 07:17 AM
Crazyfootcoy's Avatar
It cost as much as the apr which has allready proven it's self as a good wing. I was expecting the bros wing to be much cheaper
Old Jan 18, 2012 | 07:21 AM
patinum's Avatar
Thanks for the input guys. Looks like I'll probably end up with the APR GTC-200
Old Jan 18, 2012 | 09:10 AM
Uncoolron's Avatar
Old Jan 19, 2012 | 03:36 AM
Sobe_Death's Avatar
I thought that's what they were designed to stop? From the thread about the wing, they have been saying that there are braces to contour to both the outside AND inside of the trunk surface...
Old Jan 19, 2012 | 11:38 AM
CKit's Avatar
Unless there's a massive X-brace on the underside (which I doubt otherwise they'd picture it), simple and effective underside bracing will be difficult. There's trunk bracing inherent to the lid, but it's strongest at the edges where it's double seamed.
Old Jan 19, 2012 | 04:33 PM
maluch's Avatar
if you will run the wing near the roof line, in clean air, stay away from the APR wing. its designed to be mounted and be most efficient near the trunk. for clean air efficiency use simpler, flatter wings.
for clean air aero the BROS wing doenst look that bad but untested its def not worth 1300
You wont see a professional team(grand am and WC)run an APR type of element and mount it near the roof line.
Old Jan 19, 2012 | 04:43 PM
psychoazn's Avatar
Measurements per Bros:
Width of the wing : 1653mm (including the ends)
Depth of the wing : 312mm
Height front : 279mm
Height rear : 355mm
