Buying KW's
Ordered my KW's today. I want to dial some geometry back into my suspension since im going to lower my car. There are so many products available, I am confused which ones I should use. J's roll ceneter $1000
, Go fast labs, front/rear bump steer kit.....
Dont know if it matters, but im running AP2 version 1's with 235/45/17 AO48's and 255/40/17 RA1's. RA1's all around once i wear out the AO48s. Car is 03, AP1. Im hoping to lower the car about 1.75-2.0 inches. Thanx in advance guys.
, Go fast labs, front/rear bump steer kit..... Dont know if it matters, but im running AP2 version 1's with 235/45/17 AO48's and 255/40/17 RA1's. RA1's all around once i wear out the AO48s. Car is 03, AP1. Im hoping to lower the car about 1.75-2.0 inches. Thanx in advance guys.
I don't see much gain by installing pillowball mounts on a double wishbone susp worth wrenching about. I can see how it can aid in maintaining the intended susp geometry on a MacPherson strut but on a double wishbone the A-arms do all the work. You're better off spending the $$ replacing the bushings on the control arms with a stiffer compound or better yet use monoballs to get the same effect.
No need for a bumpsteer kit on an AP2. Just dial in 1/8" rear toe in and you're set.
Mr. Eurotrash has BMWs on the brain. The a-arms control the suspension geometry; the shock mounts have nothing to do with it.
Originally Posted by eurotrashdtm,Oct 2 2006, 10:09 PM
ha, good guess mr. garrison. GC camber plates were a great upgrade on my e36.
//steve\\
Apr 16, 2015 05:41 AM
dan_uk
Nov 15, 2014 05:26 PM
