Cage the s2000
Old May 25, 2017 | 04:07 AM
will010100's Avatar
Originally Posted by s2000ellier
do this https://www.s2ki.com/forums/s2000-ra.../#post22409184
and more pics https://www.s2ki.com/forums/s2000-ra.../#post22790324
gut the a-pillar and put the bar/foot box on the body rail not the floor. more ankle room more room in general
I showed a similar cage to a fabricator for quotation, and he was curious about how to access the blind welds at the bottom of the a-pillar.
Old May 25, 2017 | 07:28 AM
BlueBarchetta's Avatar
Originally Posted by jah29
Do you have a problem shifting with the seat really low? I've been thinking of putting a race seat and rollbar in mine, but I can't decide if the width and height of the center tunnel will make elbow positioning akward when shifting from a really low seat.
I'm 6 ft, 200 lbs. I have no issues with shifting or the shifter. Only issue I have is the pedals are pretty far away. But it works
Old May 25, 2017 | 07:30 AM
Originally Posted by miamirice
te farther you go with race prep, the more awkward the whole thing gets. The adrenaline will take your mind off of it. I shared a seat in a chump car that put my shins agains the crossbar, my elbows were very bent and it was really hard to straighten my arms after a 24 hour event, the shifter took wrist to throw into 2nd and 4th because it was behind me. You couldn't see anything in the mirrors With the window net and halo seat......
the point is is very few cars get better, or stay nearly the same in comfort or visibility once you go that direction.
this brings up a good point. Work with a builder who will bring you in for multiple fittings to insure everything is in a good place. You can reach everything, and you're not too close to parts of the cage.
Also my car has "NASCAR" bars on the drivers side. A little safer and easier ingress/egress.
My cage probably cost more than most, but really worth the extra to get it right
Old May 25, 2017 | 07:36 AM
t-o_double_d's Avatar
Originally Posted by decepticondc5
Here is a quick album of my cage: nasa cage - Album on Imgur
thanks for that link!
Old May 25, 2017 | 08:18 AM
s2000ellier's Avatar
blind welds are common on cages for some cars, you use a mirror and hold the gun awkwardly, slow and hard but not impossible.
Old May 25, 2017 | 09:26 AM
decepticondc5's Avatar
If you have any questions let me know.
Answers to the typical questions:
- I am 6' and have good headroom above and to the sides after modifying the buddy club rails with some custom brackets
- I hammered the floor down with a 5lb sledge so the seat is actually a little sunken down by about .5"
- My seat is in the second from the farthest back position on those those rails
- The clutch master is out of a civic to allow for more clearance for the forward bars.
- the outer gusseting on the "high X bone" portion of the tunnel only weighs about 22lbs and its a shitload of work to remove
- the hardtop is a forbidden double carbon and its been gutted so that the cage sits about 3-5mm away from the outer layers for max headroom
Old May 25, 2017 | 10:26 AM
miamirice's Avatar
Not far from you:
2007 honda s2000 for Sale in FORT MYERS, FL | RacingJunk Classifieds
Old May 25, 2017 | 01:46 PM
InsaneSp's Avatar
Here's a few more pics I haven't sent you yet but if there's any measurements or details shots that you're interested in, let me know. As mentioned previously in this thread, try and get the plinth for the A-pillar down bars to protrude less in to the footwell. The entire structure can but integrated to the rocker even if you don't gut the A-pillar itself.
Old May 25, 2017 | 02:20 PM
^ your door bars look amazing! i dont like how that foot box is next to your leg tho, gutting the a-pillar and doing it there seems so much better.
i really like how you even retained the oem door bars!
Old May 25, 2017 | 03:00 PM
miamirice's Avatar
InsaneSp----That looks great. One thing I like on that is:
nascar bars should meet the vertical tube so that if you were T-boned the horizontal bars would be in compression with the vertical bar it's welded to below the A-pillar (likewise for the rear) When you have an S bend in the horizontal the bar is more likely to shear away from the vertical bar.
I hope that that makes sense. By no means am I a cage builder but I read everything I could find before I had my civic caged
