camber question
I wanna buy a set 17x8 with 48 offset with 235 40 in front and id like 255 40 in the rear i was wondering the minimum negative camber i can have and clear the front and rear fenders... I would like to keep it around 1 to 1.5 max im about half inch drop the reson is because i have vary stif spring and azz im told u dont realy need negative camber if u have no body role
A 235 tire on a 17x8 +48 should clear with stock camber.
You didn't give an offseet for the rear? Are you looking at 17x8 +48 square?
