camber question
Old Jun 12, 2012 | 01:17 PM
megan ap1's Avatar
Default camber question
I wanna buy a set 17x8 with 48 offset with 235 40 in front and id like 255 40 in the rear i was wondering the minimum negative camber i can have and clear the front and rear fenders... I would like to keep it around 1 to 1.5 max im about half inch drop the reson is because i have vary stif spring and azz im told u dont realy need negative camber if u have no body role
Old Jun 13, 2012 | 01:22 PM
turbo8765's Avatar
Do you have a spell check? If English is not your first language, I apologize, but it looks more like ghetto slang.
A 235 tire on a 17x8 +48 should clear with stock camber.
You didn't give an offseet for the rear? Are you looking at 17x8 +48 square?
Old Jun 13, 2012 | 01:23 PM
mzk784's Avatar
You will still have body roll regardless of how stiff your springs are, what tires are you running?
Old Jun 13, 2012 | 08:35 PM
markhs2's Avatar
17X8 is a very bad size wheel to run a 255x40x17 tire on, 17x9 is ok, 9.5 is better, 10 is best.
even the 235x40 would be best on a 8.5 or 9 wide wheel
toniotran
Aug 25, 2012 10:58 AM
pd0019
Jul 7, 2010 04:30 PM
David_T
Feb 13, 2009 06:35 PM
plokivos
Apr 8, 2008 08:33 AM
mikey k
May 16, 2007 04:12 PM
