Can someone help me with PAX?
The difference between street tires and r comps(mainly purple crack) has become very marginal as of late. The big factors that make a bigger difference are course and surface. On a transitional course on asphalt the difference in tires is very minimal. On a sweeper intensive course or concrete the difference becomes more apparent. The other issue with pax is that many street classes are not developed to their potential and also certain classes destroyed others at nationals so the differentials became larger. Such cases as fmod and bsp.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
I do agree that some surfaces do further add to the rcomp advantage though, that is true and proven.Cheers,
Nick
The difference between street tires and [worn out] r comps(mainly purple crack) has become very marginal as of late. The big factors that make a bigger difference are course and surface. On a transitional course on asphalt the difference in tires is very minimal. On a sweeper intensive course or concrete the difference becomes more apparent. The other issue with pax is that many street classes are not developed to their potential and also certain classes destroyed others at nationals so the differentials became larger. Such cases as fmod and bsp.
By about 40-60 runs, a Hoosier is pretty close to a street tire. By 80-100, the street tire may be better.So if you're talking about the last 2/3rds of a R-comp's life, then agreed. Pretty marginal difference.
But if someone was inclined to run on fresh Hoosiers, big difference. BIG difference.
I do agree about transitional vs sweeper. Especially if a car is softly sprung, it can't get to the peak grip of the tire before it has to transition again in a slalom. So the extra grip of a Hoosier is wasted. But that's not the fault of the tire, it's the car and chassis that can't use the grip. Most S2000s are still stiff enough that there is still a significant transitional difference, IMHO.
lovegroova
UK & Ireland Meets & Events - Past
30
Oct 31, 2011 10:21 AM
Wisconsin S2k
Jul 20, 2002 06:55 PM
