Caster question
My car is an AP1 with 1 inch drop and hardrace offset balljoints in front. I did not install the roll center adjustment plates.
My alignment is:
Front camber 3 deg
caster 5.9 deg
toe 0
Rear camber 2.8
toe 0.26 deg total
The problem is my caster is maxed out and the guy (very very experienced with track s2000's) could not get anymore out of it. Any ideas on what can be wrong?
My alignment is:
Front camber 3 deg
caster 5.9 deg
toe 0
Rear camber 2.8
toe 0.26 deg total
The primary reason people run high caster is for dynamic negative camber gain in low speed corners, not high speed stability. No one has ever claimed their S2000's 'high speed instability' was cured by extra caster.
Sneeze2K
May 20, 2013 01:30 PM
nigels
May 14, 2010 07:41 AM
