CE28s
Old Jan 21, 2011 | 03:15 AM
bronxbomber252's Avatar
It does, but very slightly... and by just bending the tabs that the fender liner attaches to up to maybe a 45 degree angle, you are still able to attach the fender liner, and no more rubbing.
Old Jan 21, 2011 | 03:41 PM
PapiChulo's Avatar
Originally Posted by aCab,Jan 19 2011, 09:06 PM
I like how 17 x 8.5 +40 look and fit the body.
any pics of this setup?
Old Jan 22, 2011 | 05:03 PM
Antonov's Avatar
Originally Posted by Squirtle,Jan 19 2011, 06:45 PM
17x10+52 custom offset and size.
Have your fenders rolled or go wider and call it a day!
Old Jan 22, 2011 | 07:13 PM
bsyeth's Avatar
Originally Posted by WynnS123,Jan 19 2011, 07:18 PM
I would say 17x10 +50 all around. +52 may slightly rub your suspension arm on the front at full lock.
You said for The Track... and every little bit helps for maximum benefit
Old Jan 23, 2011 | 01:34 PM
PapiChulo's Avatar
You dont think the 17x10 +50 all the way around will hit the front suspension arms?
Old Jan 23, 2011 | 07:15 PM
WynnS123's Avatar
No.
The 6ULR's from 949 Racing are available in 17x10 +52. Some people that ran those up front reported light contact with the suspension arms at full lock. This did not affect some others that were running the same wheels. So that leads me to believe that 17x10 +50 will clear perfectly. You will just have to roll your fenders more, but that's better than rubbing metal on metal.
I believe Evasive has CE28N's available in 17x10 +50 in stock. This is the route I would go if cost wasn't a factor.
Old Jan 23, 2011 | 07:34 PM
WynnS123's Avatar
Here's a fb link to the CE28N's in 17x10+50 on an S2k:
http://www.facebook.com/evasivemotorsports...039.37244375317
Old Jan 24, 2011 | 11:20 AM
Orpheus's Avatar
Originally Posted by WynnS123,Jan 23 2011, 09:15 PM
No.
in addition to the arms, depending on how much you are lowered, they also hit the frame in the wheel well. +50 might give enough clearance, not sure.
512S2k
Jan 8, 2019 10:43 AM
joshf47
Jun 18, 2013 02:26 AM
mrbond413
Aug 16, 2012 03:56 PM
lastminute_s2k
Nov 25, 2009 06:24 PM
