Cheap options to balance steady sate cornering?
Old Oct 10, 2009 | 05:26 PM
robrob's Avatar
Don't forget rear wheel lift when you're adjusting your suspension. You may get a more balanced car by stiffining up the rear but if it's too stiff you'll loose drive out of the corner. It's more of a problem with r-compound tires and it's why many road racers run with a stiff front and no rear bar. Have your buddies keep an eye on your rear wheels when you run the cones.
Old Oct 10, 2009 | 05:30 PM
macr88's Avatar
I'm not saying this is you but I've noticed that sometimes people try to dive in too
deep creating a bad situation for this car. I'm not sure how true this is but I've
noticed that this car doesn't really like that style of driving and instead benefits
from being on the gas to create balance or composure.
Unlike most rear wheel drive cars I've driven in the past this car seems to get
loose in that situation where other cars don't.
Just a thought as I'm still learning.
Old Oct 10, 2009 | 06:05 PM
scareyourpassenger's Avatar
Originally Posted by SC_Highlander,Oct 10 2009, 04:43 PM
I have a very similar situation with my car. I'm running 950lb springs all around, saner on medium, no rear bar, 255x4 R888's, and Koni DA yellows. I am making the following changes: increasing the front springs to 1200lb, swapping the saner for a CR front bar, and I've ordered parts to build a 5/8ths solid rear bar. Hopefully I get that done before our next event on 10/18.
Let me know how that rear bar helps out and what parts you end up with.
Old Oct 10, 2009 | 06:09 PM
I agree, the handling changes dramatically depending on throttle application compared to the other cars I have driven.
Old Oct 10, 2009 | 07:30 PM
tinkfist's Avatar
How much have you played with the KW adjustments? That's a free option that may make the right difference for you.
Old Oct 10, 2009 | 07:38 PM
robrob's Avatar
Driving style (how abrupt or smooth on steering, brakes, throttle) makes a big difference in how this car handles. It responds well to trail braking in slow speed corners and maintenance throttle in high speed corners.
Many times the handling problem is caused by the control actuator.
Old Oct 10, 2009 | 10:23 PM
Billj747's Avatar
First off, what are your dampers set at?
What HOT tire pressures are you running?
If the front bar on full stiff (no rear bar) made the car understeer too much, what about the front bar full stiff and the stock rear bar on?
If you are going up in spring rate, get the 571lb (~10.3Kg) Clubsport rates, the ~50lb difference to the 515lb won't be that noticeable. I don't think -2.7* of rear camber would be too much. Anything under -3* seems to be okay for the street.
Old Oct 11, 2009 | 04:46 AM
[QUOTE=Billj747,Oct 10 2009, 10:23 PM] First off, what are your dampers set at?
Old Oct 11, 2009 | 05:53 AM
Billj747's Avatar
"--So far I have tried the front bar full stiff and I am getting inlift with the rear bar connected. (oversteer)
--I tried full soft on the front bar and the rear disconnected and it understeered badly."
Where was the oversteer when you had the front bar full stiff with rear bar connected? Entry/mid/ exit? Were you trailbraking, on the gas, etc...?
Where was the understeer when you had the front bar full soft with rear bar disconnected?
50lbs isn't worth it and won't be that noticeable.
Old Oct 11, 2009 | 01:13 PM
All the issues are mainly during mid corner while on the gas but not to unsettle the car. I can't roll on the gas near as quick as when I have the rear bar disconnected.
