CMP Thursday the 11th
Old Jun 8, 2009 | 06:55 PM
9kI4's Avatar
you should come to VIR with NASA-MA in July
Old Jun 8, 2009 | 08:38 PM
WynnS123's Avatar
Originally Posted by Momentum,Jun 8 2009, 12:21 PM
315 35 18's and 295 35 18's (hoosier R6)
10 and 11" rims
Putting down 575, I'll start with 400 at the track and work my way up.
That is one BMF'n S! What are your wheel specs and do you rub at all?
Old Jun 9, 2009 | 05:12 AM
Momentum's Avatar
9Ki4: I might VIR is my favorite track (within 5 hours anyway) so I try to get up there when I can.
Wynn: 18x10's and 18x11's and I dont know the offset because I milled them down to fit. I don't rub but my fenders are pulled in the rear to the point of creasing them.
Old Jun 9, 2009 | 01:02 PM
AP2Berlina's Avatar
awesome track setup you got there very nice
Old Jun 11, 2009 | 06:48 AM
Momentum's Avatar
front right brake caliper came apart went through my rim, rim exploded took out my fender, headlight, and a rod end from my upper control arm. Found the caliper on track with 1 sheared off bolt and a sheared slider. Hard to tell what happened exactly but I know the bolts were tight. It appears like the outside part of the caliper (with the sliders on it) broke loose and hit the rim.
Old Jun 11, 2009 | 06:51 AM
Momentum's Avatar
On the plus side the temps were pretty low 4 laps in lol
Old Jun 11, 2009 | 07:13 AM
SC_Highlander's Avatar
Sorry for your misfortune.
Are you sure it was the caliper that came apart first and not the arm? My upper control arm failed on the left side andcaused similar damage, though the caliper did stay attached to the caliper bracket and the knuckle...
Old Jun 11, 2009 | 08:08 AM
Momentum's Avatar
yeah the caliper is trashed one of the bolts is sheared off still in it and one of the sliders is sheared off (from what I can tell the slider failed) the control arm is actually still in one piece so I guess thats a pretty good test
josserman
Aug 21, 2014 04:07 AM
PB Motorsport
Αγοραπωλησίες
Feb 13, 2014 10:42 PM
eastonh477
Feb 4, 2014 08:12 PM
josserman
Mar 30, 2010 05:39 AM
josserman
Mar 29, 2010 06:02 PM
