Comptech Race bar settings?
Originally Posted by SC_Highlander,Aug 29 2005, 03:44 PM
I'm running 1 hole off of full-stiff on Hankook RS-2's 225/245, but my rear shocks are toast.
Originally Posted by TubeDriver,Aug 29 2005, 06:10 AM
What setting have people with the Comptech Race front sway bar found works with 225/245 on asphalt? RA-1s or Victoracers? Thanks.
i got 225f. 245r. victoRacer w/ comptech adj. f. sway bar(not yet installed) also right now my tire pressure is at 32.5 psi F. 30 psi R.
should i put the sway bar at full stiff and put 35psi F. 33.5psi R.??
*everything else is stock
thx.
I've been running mine on full stiff since I got it a few years ago. Most of our events are on asphalt. The car is stock, including shocks. Alignment is -1.5 deg. front and -2.0 deg. rear with ~1/8" total toe in for the rear. I do get some understeer but that's more likely due to the use of 265s on the rear. 30 psi for the 710s all around...
Thanks for the info. I'll probably start with one setting below full stiff (just because I like the rear a little lose) and adjust accordingly if needed. The tires pressures you all use are pretty close to what I run (33-35 front and 31-33 rear). I generally set and forget because I am lazy.
tcl
Jun 24, 2008 08:31 AM
tcl
Jun 16, 2008 08:17 PM
