CR sway bars
I have an 06 S2k and was wanting to go with bigger sway bars. The car has Bilstein PSS9 coilvers set at level 2. (1 being stiffest) The car has more body roll than I would like and was wondering if some better bars would correct this without hurting skidpad performance.
That said, are the CR say bars a good upgrade or is there any difference in sizing between the two?
Thanks, also what brand otherwise is recommended?
MY2000 Front 28.2MM T5.0 Rear 27.2MM T5.3
MY2002 Front 26.5MM T4.5 Rear 27.2MM T4.5
MY2004 Front 26.5MM T4.5 Rear 25.4MM T4.5
MY2006 Front 26.5MM T4.5 Rear 25.4MM T4.5
MY2008 Front 27.2mm Rear 25.4mm
CR2008 Front 28.6mm Rear 26.5mm
CR front 19% thicker wall than std.2008, rear the same wall thickness as std.2008
Hmm, I don't know about that. I switched from MY03 to MY08 front springs and I did notice a difference. I am even considering getting MY00/01 rear sway bar--same diameter but slightly thicker. There's got to be a way to increase front grip... (within S2K Challenge rules).
Well, I'm thinking of going with a thicker rear sway bar to increase front grip (if it works that way). My suspension is stock MY2003, except for MY2008 front springs (slightly stiffer), J's S2 camber kit front, SPC camber kit rear, 225/255 NT01. Alignment: camber is set to -3.0 all around, 6.2 caster, 0 toe front, 1/8 total toe-in rear. Once I get my BSK in, I'm thinking of going with 1/16 total toe-in.
