Cracked Rotor!
Thanks, Mike. I think I'm ok. You saw the rotors I had taken off, and you said they actually aren't so bad, so they should get me through Tuesday's track day. I have a spare good one that I'll bring, and I've ordered a couple of OEM ones form H & A.
Yeah, changing rotors is so easy (if you can get the screws holding them in off) that I always take spare rotors to track days.
See you guys on Tuesday.
Originally Posted by 124Spider,Sep 3 2005, 09:47 AM
Is there some sort of "bedding" process one is supposed to do for new rotors, analogous to the bedding of new brake pads?
One thing to think about. I have heard that you want to run new rotors on the street for a week or so before hitting the track. This has nothing to do with the pad/rotor bedding in process. Rather, you want the rotor to undergo several moderate heating and cooling cycles before nailing it at the track. I run the G3000 rotors with XP8s and have not had any problems although I have the little hairline heat/stress cracks.
With the WRX (which is woefully underbraked compared to the S2000), a vender with strong ties to carbotech was telling me about how he was getting complaints about a certain brand of rotor. It seems that if the rotor was driven moderately on the street before going to the track the rotor would last for a long time. If the rotor was just bedded in and than run on the track it would crack and self destruct.
Well, I got through the track day without problems with the old rotors, but I just swapped the street pads and tires back on, and the cracks on the right front rotor have opened up a lot more. I don't think I'll be doing another track day on these puppies.
Originally Posted by rlaifatt,Sep 7 2005, 08:57 PM
Were the matching front rotors, e.g., both OEM?
I have ordered two new OEM front rotors, which I will put on when they arrive.
Originally Posted by bridow,Sep 7 2005, 12:04 PM
ive always heard; get the cheap rotors because all of them will wear or break just the same.
Originally Posted by Race Miata,Sep 7 2005, 10:40 PM
from my miata experience, the cheap Brembo replacement rotors easily got warped even when brand new and with just street driving.
