Crank Scraper
Old Nov 7, 2017 | 07:01 PM
s2000sccaracer's Avatar
Default Crank Scraper
I have been looking for a crank scraper for an F20c engine, but have not found one commercially available. Anyone know of any?
I contacted Ishihara-Johnson Crank Scrapers, since they have one for the Honda F and H series engines, but it will not fit the F20c. To develop one, they will need a short block with an oil pan and oil pump. This does not need to be a good engine, but would need to rotate. Would anybody in the Tampa, FL area (Ishihara-Johnson Crank Scrapers is in Port Richie) have an AP1 short block that they could loan to them? I can probably piece one together, but would rather not have to pay for shipping it back and forth from CT. If a scraper were also to be developed for an F22c engine, an AP2 short block would also be needed, since the stroke is longer.
Old Nov 7, 2017 | 07:06 PM
Chibo's Avatar
If this happens please report back
Old Nov 8, 2017 | 03:44 AM
freq's Avatar
Funny.
I was just reading this old thread regarding baffles and scrapers.
https://www.s2ki.com/forums/s2000-ra...esigns-536270/
Old Nov 8, 2017 | 08:45 PM
DavidNJ's Avatar
Isn't the crank and rod throws completely covered by the lower girdle with the main caps? That would preclude a scraper.
Old Nov 9, 2017 | 03:28 AM
ajohnson's Avatar
I could see a crank scraper easily there.
Windage tray wouldn’t necessarily be needed
Old Nov 11, 2017 | 12:02 AM
djsilverjohnson's Avatar
I'm working on a Nissan VQ30DE now and I've found that all the VQ motors have a windage tray bolted to the aluminum ladder support that's bolted to the bearing caps (even the truck versions). The main bolts/studs pass thru the bearing caps and through the ladder support. The newer VQ37VHR has a "mid-block" design like the F20C with the bearing caps and girdle in one piece, but still uses a windage tray.
s2000sccaracer
Tampa
Nov 10, 2017 05:24 PM
washmyburn
Oklahoma Classifieds
Jan 15, 2016 08:15 AM
washmyburn
Jan 2, 2016 07:02 PM
alexrosiu
Aug 31, 2015 06:55 AM
tkm_dave
Aug 31, 2014 11:30 AM
