Designing better APR GTC200 Endplates
#32
Now that you've got the flat end plates mastered, what about bent end plates? I know there was discussion that they could not curve outward like the new 737 because it would widen the wing. What about curving the bottom inward? It looks like Lamborghini sees an improvement in this feature.
#33
Why not make a cold air intake for forced induction S2000s? Every car with a turbo seems to have a huge K&N filter sitting behind the radiator...which is really behind the intercooler, A/C, oil cooler, and radiator. That air can't be cool. Supra's often take out the right side headlight for cold air.
It is a tight fit in the S2000. Virtually all supercharged ones have a centrifugal compressor sitting n front of the engine. Some of the turbocharged ones have the turbo in front of the engine. But even those with the turbo along side the engine have the air filter behind the radiator.
It gets even trickier. Many of these cars see track days or even competition. Those cars will virtually all have brake cooling ducts (you made ducts also) using the front panels. In all cases it has to be able to handle rainy and snowy days without water getting in the engine.
This isn't a simple problem. It probably will need a top piece in the hood and a bottom piece that that contains the air filter. Fortunately the silicon ducting often used to the compressor inlet offers lots of configuration options.
#34
#35
I honestly have never seen a FI S2000 at the track yet.
#37
https://motoiq.com/project-s2000-par...ers-and-vents/
Hood NACA duct which could be used to provide cold air to a turbo inlet:
https://motoiq.com/project-s2000-par...t-air-testing/
#38
FYI. Some air temp measurements off heat exchangers:
#39
This video discusses the aerodynamics of the vertical slats on the bottom of wing endplates, using the 2019 F1 Ferrari as the example.
https://youtu.be/DNROTNOg558?t=398
#40
