Which diff fluid?
Old Jul 25, 2010 | 12:34 AM
cgper's Avatar
Default Which diff fluid?
Hi guys, I think its time for me to do a fluid change. I'm planning on using Mobil 1 75w90. Is this a good oil? I will be going to buttonwillow at the end of the month and forecast shows its gonna be about 100F that day.
I'd like to know what you guys are using.
Thanks in advance
Old Jul 25, 2010 | 03:46 AM
spets's Avatar
I'd rather use a bit of a heavier weight, like LE1605 or Amsoil 75w110.
Old Jul 25, 2010 | 08:44 AM
INTJ's Avatar
Old Jul 25, 2010 | 09:45 AM
Orthonormal's Avatar
I'm inclined to stick with the factory specification of a 90 weight (not multi-grade) GL-5 gear oil. I have been using the LE 607, and switched to LE 1605 although it has a higher viscosity (it is still GL-5). Next time I may try to locate Motul PA90, which is an SAE90 GL-5 oil.
I autocross only, no track.
Old Jul 25, 2010 | 12:27 PM
WynnS123's Avatar
I use 75/140 Mobil 1. It's specified for light trucks and SUV's.
Old Jul 25, 2010 | 12:46 PM
Mark355's Avatar
I just replaced my diff fluid with Mobil1 75w90 LS synthetic. Seems fine!
Old Jul 25, 2010 | 03:57 PM
INTJ's Avatar
LS is limited slip...
Old Jul 25, 2010 | 04:16 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Amsoil 75W140.
Old Jul 27, 2010 | 07:48 AM
HotDamnitsDavid's Avatar
Originally Posted by Emil St-Hilaire,Jul 25 2010, 07:16 PM
Amsoil 75W140.
Same here
Old Jul 27, 2010 | 08:43 AM
CourageOO7's Avatar
PuddyDad recommends a 75W140 for all track cars. I also use the Mobil 1. I just spoke to him about this and he says the 90W is not heavy enough. He says a minimum of 110 for street cars as it won't sheer down quite as much.
