Diff and Trans cooler
Old Mar 22, 2010 | 06:03 AM
Andrew Wojteczko's Avatar
Default Diff and Trans cooler
Hey,
Just started the fab and fitting of some Fluidyne coolers with Tilton pumps and Mocal fittings I'm planning to use to cool the diff and trans in the unlimited S2k build. The coolers/pumps/filters will increase fluid capacity and help keep metal particles out of the diff/gearbox which I'm hoping will increase life in addition to the cooler running temps. With the underbody fully sealed off I'm confident additional cooling will be necessary.
Here are some photos of the progress.
there are two separate cores with one shroud and fan. The Spal fans are available in pushers and pullers, we need a pusher for this application.
more here
Thanks,
Andrew
Old Mar 22, 2010 | 10:57 AM
SLINKYDOG's Avatar
your build is very clean and professional looking
thanks for showing us how thing are going.
any more info on the trany install
Old Mar 22, 2010 | 11:53 AM
modMonkey's Avatar
Very cool. Clever place to put it. The shroud looks nice.
Old Mar 22, 2010 | 12:21 PM
CourageOO7's Avatar
Excellent build. It's fun to see these kinds of builds and get ideas or just learn something new.
Old Mar 22, 2010 | 12:53 PM
s2kobsession's Avatar
Old Mar 22, 2010 | 05:39 PM
iApex's Avatar
Awesome build. You should start an official build thread and document the entire build.
Old Mar 22, 2010 | 07:34 PM
Opc's Avatar
Opc
can you run for president of honda
Old Mar 23, 2010 | 08:12 AM
haha thanks guys!!
Will keep progress updates coming. Pumps are here and I have worked out the mounting location, will install shortly. Waiting on fittings and filters.
Trans prop shaft and clutch are all worked out, will post more up on that shortly.
Old Mar 23, 2010 | 09:59 AM
hondaf1's Avatar
Is the trunk vented to get more air to the rear cooler. Wouldn't there be enough air coming through the front windows. Seems like the vented trunk might interrupt the air flow.
Nice build BTW.
Old Mar 23, 2010 | 10:30 AM
Trunk has been opened up just to reduce weight, it is fully covered by the rear section of the spoon roof.
