Diffs and Coolers
I'm gonna pick up a clutch type diff for my race car. What brands are you guys in T3 using? I figured I'd just get the Kaaz since they're easy to come by but some of you have used another carbon type (I forget the brand off the top of my head).
Also what have you guys done about cooling. I know in T3 you're not allowed to alter the housing which causes some trouble. I'm not restricted to that. I'm figuring I'll use the fill hole and have another bung welded on since the drain hole would be a bad place to put a 90.
-Ry
-Ry
May not be as important for you other than 1.5 way vs 2 way. Does KAAZ have a 1.5 way?
Why ATS? ATS carbon engages smoother than non-carbon types (KAAZ,etc) which was important for T2 (now T3) because there is less chassis input which was an issue because of having to use stock springs.
Originally Posted by stocky,Jan 1 2008, 07:22 AM
Rylan did you run the stock stiff until now? any failures?
Lost a r&p in Jan 04, replaced w/ a mazda 4.44 and have been running that since.
-Ry
