Driving Technique
What about for a car that is not very aero assisted? E.g. in my car, the fastest way through turn 2 at WSIR is to let the rear steer the car around the corner, which equates to sawing at the steering. More aero assisted cars will have a more consistent constant steering angle through the corner. In all cases, the turn is taken WOT after initial turn-in. It is slightly banked (few degrees), and uphill. Cornering speed is ~90mph give or take a few mph.
http://maps.google.com/?ll=34.871479...m&z=16&vpsrc=6
I've developed a habit of mildly sawing at the steering in any situation where I'm unsure of the absolute grip of the car (waving back and forth maybe 10 degrees). I've noticed that rally drivers tend to do so (albeit with good reason). Charles Ng also is constantly sawing, but he's been quite successful racing.
This is not to say a smooth driver is fast and vice versa. They could just be slow, but smooth. Similarly, a fast driver is not necessarily smooth, but I bet he could be faster if he was smooth - slow hands for speed, fast hands only to catch a slide or if you want to look cool on camera.
Even in low traction environments such as rally, the fastest drivers are the smoothest. Just look at Sebastian Loeb.
All this being said, I am not the fastest or the smoothest driver out there (even though I like to think so)
Hence my "smooth(er)" comment. He is actually very smooth considering the narrow streets and jumps
I know that feeling and catch myself doing it too. Sawing a bit can give you feedback about whether or not either end of the car can take more. But I think it would obviously be fastest to just know already whether the car is at the limit and only steer as necessary to keep it there, once that level of skill is attained. Random sawing may give you more data to work with but it also upsets the car. It's a crutch I will need to grow out of to get faster.
Originally Posted by psychoazn' timestamp='1325718600' post='21286342
What about for a car that is not very aero assisted? E.g. in my car, the fastest way through turn 2 at WSIR is to let the rear steer the car around the corner, which equates to sawing at the steering. More aero assisted cars will have a more consistent constant steering angle through the corner. In all cases, the turn is taken WOT after initial turn-in. It is slightly banked (few degrees), and uphill. Cornering speed is ~90mph give or take a few mph.http://maps.google.com/?ll=34.871479,-118.262415&spn=0.016179,0.033023&t=m&z=16&vpsrc=6I 've developed a habit of mildly sawing at the steering in any situation where I'm unsure of the absolute grip of the car (waving back and forth maybe 10 degrees). I've noticed that rally drivers tend to do so (albeit with good reason). Charles Ng also is constantly sawing, but he's been quite successful racing.
Even in low traction environments such as rally, the fastest drivers are the smoothest. Just look at Sebastian Loeb. All this being said, I am not the fastest or the smoothest driver out there (even though I like to think so)
To add to this, here's an interesting tidbit. The guys with larger wings will go through the turn with positive input, WOT. The guys with a CR wing or no wing ultimately end up going though in a state of what we call zero-counter. We aren't turning the car with the front wheels, but we're not countersteering either. Effectively the rear is both accelerating the car and turning it.
Here's an example from s2k challenge @ https://www.s2ki.com/s2000/topic/902...9-wsir-results
First and third for this event were separated by 0.099 seconds...
1:36.892 - Ddess
1:36.965 - psychoazn
1:36.991 - takchi
Both takchi and I are driving CR with non-staggered wheels/tires (RS-3), and an exhaust (no other performance mods). We are both taking the turn in that "zero-counter" state, while Ddess is running a AP1 with GTC-200, and non-staggered NT01.
I do agree that a smooth input SHOULD be faster, but I find myself sawing more and more as I improve. One thing to note is that sawing has a larger impact with stiffer springs and damping, and all three of the above mentioned drivers are running stock suspensions. I rarely find myself sawing when I drive other s2ks with coilovers except to correct.
mattnyu99
Mar 2, 2005 12:07 PM
CoralDoc
Feb 10, 2004 03:59 AM
rankoslavujevic
Oct 23, 2002 02:05 AM
