Evidence of hard braking
Old Oct 3, 2004 | 02:50 PM
gomarlins3's Avatar
Default Evidence of hard braking
Thanks for a fun day at Buttonwillow folks. I had a good time. I decided not to run my fourth run group and head home since it was the wife's Bday and hse had said it was alright I go and drive. When I got off to fill up at the next exit, I had a VERY loud noise coming from my brakes. I figured I was down to the wear indicator on the pads.
When I got off at Kettleman, the 'BRAKE" light came on, yet my E-brake handle was down. Yup, brakes were definitly gone. By down shifting ealry and using the E-brake, i made it home to Fresno. This morning I put the car on stands and took off the wheel. Look what I found:
A lot of brake dust on the wheel and NO PAD left on any of the front pads. Swapped them out for the mew ones I had ordered after the past track day with SV. When they recommend 5mm of pads left, 5mm is what they mean. I used all of it.
And yes, the dark area on the caliper is burned paint.
P.S. Can I 'burn' brake fluid?
Old Oct 4, 2004 | 05:45 PM
drewchie's Avatar
It was a very tough weekend for painted calipers. I'll post some picks of mine when I get home.
I was running Cobalt GT Sport pads, and Motul RBF600 for fluid. You should definitely be using a high temp racing fluid if you're not already.
Old Oct 4, 2004 | 05:54 PM
jerrypeterson's Avatar
Brake fluid is most definitely flammable.
https://www.s2ki.com/forums/index.php?showt...l=manly+destroy
If you really 'need' to paint your calipers, spray on BBQ or engine paint will survive the heat.
Old Oct 4, 2004 | 06:19 PM
drewchie's Avatar
As for surviving the heat... I used special high temp caliper paint.
Didn't help...
Old Oct 4, 2004 | 06:48 PM
drewchie's Avatar
A little history...
Before:
After:
(No, the chrome didn't cook off the wheels... the wheels are different, the calipers the same.)
Old Oct 4, 2004 | 07:22 PM
Nobody's Avatar
I cooked my brakes the first time I went to the track as well. Nothing like knowing where your brake markers are, but not knowing exactly how much your brakes are going to slow you down.
Vent your brakes, gentlemen, and consider your burnt paint hardcore.
Old Oct 5, 2004 | 06:02 AM
gomarlins3's Avatar
I was using Motol 600. I am switching to Wilwood 600 which has a higher wet boiling point. I am planning on putting a layer of bbq high temp before I repaint with the hight temp caliper paint (again).
Old Oct 5, 2004 | 10:17 AM
krazik's Avatar
Administrator
be proud. you used your brakes well. There is no paint/coating that will hold up to a well driven s2k, especially at bw.
Old Oct 5, 2004 | 10:29 AM
gomarlins3's Avatar
Well then, I guess I did something right.
Old Oct 5, 2004 | 10:36 AM
krazik's Avatar
Administrator
panicbrake
Aug 10, 2015 06:57 AM
ge2
Sep 27, 2008 04:39 AM
LHP_Sailor1P
Dec 22, 2006 10:48 AM
AquilaEagle
Apr 4, 2004 06:38 AM
AquilaEagle
Apr 3, 2004 12:08 PM
