F2000 first driving impressions
Old May 18, 2007 | 06:20 PM
  #51
SoCal Craig's Avatar
Originally Posted by krazik,May 18 2007, 05:34 AM
Craigs worried the radical west crew might see that his balls havent descended yet.
*ducks*
They know I have no balls. If I did, I'd never lift entering T9 at WSIR
Old May 18, 2007 | 06:35 PM
  #52
krazik's Avatar
Administrator
oh thats right, I forgot your balls show up as missing too on the data
Not lifting for 9 must be SCARY!
Old May 18, 2007 | 06:46 PM
  #53
Stephenopoly's Avatar
Originally Posted by rlaifatt,May 16 2007, 12:42 PM
The key is it is still all a single point release. You turn the cam buckle and all the straps (8 of them) are instantly loose, and you exit (by yourself or hauled out) with your helmet and HANS on. Same for all formula cars, and a much easier and faster exit than from a street-racecar with a caged top, so actually safer in my view.
Ok very nice
Old May 18, 2007 | 09:07 PM
  #54
Borbor's Avatar
Mygale is alright; Tatuus is the best chassis I've worked on. Elan simply SUCKS. NOTHING fits from the parts trailer when you run Elans; Tatuus I've replaced corners of a car, jigged the wishbones to the dimension of the one before the crash and all the camber, caster and toe were EXACTLY the same. All the bolts fit into the holes, simply superb manufacturing.
Mygale wasn't bad, but wasn't as nice as the Tatuus.
Don't even get me started on the Elans...those POS'es
Old May 18, 2007 | 09:40 PM
  #55
rlaifatt's Avatar
Thanks for the info. I almost got a Van Diemen (Elan) but the sale fell through and was fortunate I guess to get the Mygale (Tatuus doesn't make an F2000). I've also heard from others that the VD's are not as well designed but on the track the differences are negligible so driver is the key variable (as should be in a spec series). I think VD's look sleeker though.
Old May 20, 2007 | 10:14 AM
  #56
stocky's Avatar
Richard, your caar is it monocoque or frame ?!
Old May 20, 2007 | 11:23 AM
  #57
rlaifatt's Avatar
Frame.
Old May 20, 2007 | 11:34 AM
  #58
stocky's Avatar
Originally Posted by rlaifatt,May 20 2007, 07:23 PM
Frame.
On mine (monocoque) the engine and gearbox is part of the structure .
Is that the case also with yours?!
Old May 20, 2007 | 11:45 AM
  #59
rlaifatt's Avatar
Yes, definitely. The rear suspension hangs on the bell housing and the gearbox. The wing hangs on the endplate cover of the gearbox.
Old May 20, 2007 | 12:22 PM
  #60
stocky's Avatar
Very clean setup there!
Ws2006
Jun 7, 2010 05:50 AM
J-rod
Feb 6, 2007 01:53 PM
Lurking Lawyer
Mar 20, 2006 04:57 AM
fin man
Oct 5, 2005 03:18 PM
kamehamaha
Apr 13, 2002 12:08 AM
