F24 stroker kit for race use
This is going off memory not receipts but this is how I remember mine.
Engines....
Used engine #1 $900
Used engine #2 $400
Bran new block, crank, rods, pistons, machineshop work , bearings etc etc Engine #3 $4500
Engine number one Built 12:1 pistons Eagle Rods and Machine work $1500
Engine number two Built, Same pistons, added Carrilo Rods, new bearings Machine work $1900
Cylinder head
Ported TSX head with Ferrera Valves and Valve springs $2800
Tuning and dyno time $1000 (most recent)
Tuning and work hunting an issue $1700 (previous).
Cams
Kelford B's $800
Drag Cartel 4's with Custom VTC pulley $1300
Intake
Intake Manifold Adapter to use Stock Intake $200
Excessive manufacturing Kpro Manifold with velocity stacks and spacer $800
74mm Throttle body used $100ish
New Starter (from honda) the autozone one failed
New Alternator (from honda) the autozone one failed
New Water Pump from Honda
New Crank pulley (junk yard motor crank pulleys looked destroyed).
Injecotors and fuel rail.
550 cc injectors and inline pro Rail ($500 ish)
RDX injectors and Skunk rail ($400 ish).
Haltech ECU $1100
Engine mounts and brackets and adapter to OS Giken Clutch $1500
Headers
Custom Stainless headers header $1200
ASP custom header $1800
$400 in misc parts from one of the Kswap companies for Tstat housing and water outlet on the back of the head.
I'm sure theres more, but you can kinda get the idea.This doesn't even cover the nickle and dime stuff. For Instance I got sick of running to Ace every hour for nuts and bolts so I ordered an insane number of nuts and bolts from Honda just to make sure I had a huge stack to keep working when I worked on it. I think I spent $400 in nuts and bolts. I have enough spares to do this swap again 4 times. Also not included is gaskets and seals of which all were new each time I replaced the engine.
Now I must Delete this so my wife doesn't see it.
Engines....
Used engine #1 $900
Used engine #2 $400
Cylinder head
Cams
Kelford B's $800
Intake
Haltech ECU $1100
Headers
Engines....
Used engine #1 $900
Used engine #2 $400
Cylinder head
Cams
Kelford B's $800
Intake
Haltech ECU $1100
Headers
Engines....
Used engine #1 $900
Used engine #2 $400
Cylinder head
Cams
Kelford B's $800
Intake
Haltech ECU $1100
Headers
Oh and I did almost buy a CTR head just to "experiment".
Now I have sold a number of the things I took off, but at a fraction of what I paid for the parts.
Would a K24 crate engine have simplified things? http://www.kmodperformance.com/KMOD-...e-Engines.html
Originally Posted by DavidNJ' timestamp='1434587819' post='23651847
Would a K24 crate engine have simplified things? http://www.kmodperfo...te-Engines.html
Maybe, Maybe not. The Budget pretty decent HP build would be to mod a S2000 header to fit (I have one 90% of the way modded, it just need a really good welder to finish it). Port the daylights out of the S2000 Intake manifold. Use a Civic Si or CTR cylinder head with some less aggressive cams, Use an accord block, Run some 12.5:1 Forged Pistons and good rods. That's the way to get it done for Under $10k. The sad part is I think you'll make similar power to where I'm at. Difference is I think Mine can make a ton more power with some more RPM and more compression, where as I think the above setup would be tapped out. But you gain the VTC control and that's pretty valuable for mid range power. Thats something the F24 can't get.
Originally Posted by Mrsideways' timestamp='1434634321' post='23652250
[quote name='DavidNJ' timestamp='1434587819' post='23651847']
[/quote]
That's what I did. First one I designed and had built, 2nd one I had ASP design and build it.
I have always been told the intake for the F motor was the bottle neck. ITB's seem expensive so I would like to see what comes of this:
http://cms.skunk2.com/id/1007/Sneak-...take-Manifold/
http://cms.skunk2.co...ntake-Manifold/
From the text it seems the ITB cured intake restrictions, they used a billet cam with a severe ramp, my guess is on both VTEC and non-VTEC lobes, a header tuned to the cam, and ECU tuning for the package. Not cheap, the bolt-ons were over $10k.
http://www.superstre...a-s2000-tuning/
