First time at 1/4 mile track results
Last night was my first time ever running my s2 since i got it roughly 2 weeks ago. My first attempt resulted horribly! I was at the staging lane and i was reving between 5-5500rpm with the clutch half engaged, when the light turned green i let of the clutch and hit the gas and the car slipped like theres no tomorrow. I was so upset thinking my clutch is gone. The times resulted:
60'-2.666 (ZzZzZz)
1/4-15.3@93.4
I then talked to my friend who was with me (224whpBERLINA) and he said its not the clutch and to do more of a dropping technique rather then slipping the clutch. So 2nd run I managed.
60'-2.370
1/4-15.0@93.6
For my last run I reved it a little higher and came out the hole better resulting in,
60'-2.28
1/4-14.55@94.8
Each run Im shifting right when the red lines flash (9200?) What do you all think of the times? Its a bone stock s2k. keep in mind im in FL where it was hot as balls last night with humidity out the asss.
BTW- i noticed when i was shifting i heard this sound like a little whistle, sounds kind of like a B.O.V. Any clue what that could be??
60'-2.666 (ZzZzZz)
1/4-15.3@93.4
60'-2.370
1/4-15.0@93.6
60'-2.28
1/4-14.55@94.8
Before someone says something that might be rude...let me welcome you to S2ki. I know it looks like this is the right forum in S2ki to post 1/4 results, however the Racing & Comp forum is for people who like to turn right and left really really hard.
1/4 mile results are welcomed in the Street Encounters forum of S2ki. Perhaps a mod can help this post find it's way there.
if its any consolation...im in FL and im trapping right around there the 2 times ive been... were pretty close to sea level, but i wonder if the high humidity can make the difference?
im sure my shifting can use some help too... but the car should be trapping ~98-100 if conditions are right...
60'-2.28
1/4-14.55@94.8
60'-2.28
1/4-14.55@94.8
One thing I didn't notice was mileage on the car; what state of tune it was in(recent valve adjustment or fluids change),or tire pressures
Good launch technique is vital and buzzing it to 9200 is a mistake IMHO;try shifting @ 8000 and run it thru the traps in 4th gear
See if that doesn't help
the car has 28000 miles. If i shift at 8000 ill fall out of vtec for a second..
as far as the serpentine belt, is that normal?? tire pressure is stock, as well as everything else. im working on getting a spoon ecu from a friend and a test pipe, when funds come in.
At most dragsrips if you compete in a convertible and run 13.99 or quicker they will require a rollcage;keep that in mind.
I would also play with tire pressures but you'll need a good air tank and tire gauge for that.
