Fluid change frequency?
This gonna be good.As for me, I'm about 75% track 25% street and I change all my fluid at the beginning of a season. (4-6 track days a year.)
Started doing oil analysis' but I think it's too early to draw a conclusion from that. I may adjust my changes if the analysis warrants it though.
Why would you risk it? Especially when you consider what typical oil temperatures in an S2000 on track can be. If you're doing 30 minute sessions, and you don't have an aftermarket oil cooler, I'd change it at least every other track day. Oil is cheap. F motors aren't. Pretty cut and dry.
so your saying “because I feel better doing it” and it’s not based on any science. And that’s your prerogative, but your response to his post was as if you had scientific info (I.e. data from f22 motor oil analysis on your side). I don’t know what the answer is....but again...black stone analysis is REAL vs. a “feel good” methodology. I talk to some guys that run Global MX-5. They have 2 cars and a semi supplied by Mazda. I asked them how often should I change oil in my spec Miata and the answer was “run at least 4 days and then work off your oil analysis”. So their history in running the NA chasis and sending oil samples got them to the “4 day minimum” if you will. So if your “oil is cheep and motors are not” is what is cut and dry, that’s true.
I just use Mobil 1 Full Syn @ 10W30, it's $22 for a 5 quart jug, and with rebates, it's half of that.
I'll continue to change my engine oil every 3 days, oil filter every 6 days and trans fluid every 9 days or so. Trans is just 1 quart at ~$7 /. Cheap insurance.
I don’t know how basing your decision on a lab analysis of your oil is “risking it”.
There’s nothing wrong with what you do. It works for you. I am not trying to change your mind. But the science involved in answering the OP question lies in the oil analysis. Color, oil temps, type of oil ......blah, blah, blah....that’s all pretty empirical stuff if your not analyzing the oil. So if the OP wants to go with the average of the herd....he can read through all the answers and graph it out. Or, he can send some oil samples and get an idea of what’s going on and even learn about possible concerns with the health of the motor.
I also know about high reving Honda motors. I have a k20 that runs a 9400 redline that runs sprints and enduro. I do agree with you that the F motors will run high oil temps when water temps are norm. I wouldn’t have a track only F without an oil cooler personally.
