Front Brake Piston boot crack
Old Feb 26, 2010 | 03:50 PM
Master Apex's Avatar
Default Front Brake Piston boot crack
During brake pad replacement, I just noticed that one of my front brake piston rubber boot is cracked. There is no leak but is it still ok to track the car?
How do you replace or rebuild the piston seal/boot?
Thanks.
Old Feb 26, 2010 | 03:54 PM
Fast Driver's Avatar
Did you mean this rubber crack like this:
If so, I think it is ok as long as there is no leak.
Old Feb 26, 2010 | 04:36 PM
macr88's Avatar
It is ok but make sure you clean the piston before pushing it back in when you replace the pads.
Old Feb 26, 2010 | 05:59 PM
TKim103's Avatar
i would say no
Old Feb 26, 2010 | 08:43 PM
Yes, that is what it looks like.
Why not TKim103?
Old Feb 26, 2010 | 09:06 PM
bellwilliam's Avatar
umm. racing calipers don't have boot.
my S brake boot was gone less than 24 hours after I bought it (track it next day). never bothered with it.
Old Feb 26, 2010 | 09:57 PM
Elistan's Avatar
I've had to rebuild calipers on two different S2000s because they each had a brake seize due to grit getting onto a brake piston because of torn boots. Happened on the highway on one, and I'm surprised the resulting heat didn't ruin anything - I pulled over quickly enough, thankfully. Had to limp home - and I was on my way to an autocross.
It's kind of a PITA getting it all put back together, but no special tools are needed and it's really cheap.
Part 1, less than $20.
Old Feb 26, 2010 | 11:28 PM
Voodoo_S2K's Avatar
Thanks.
It is okay to track the car, but I would get the seal replaced sooner than later.
Old Feb 27, 2010 | 05:27 AM
TKim103's Avatar
Why not TKim103?
I have no personal experience of them failing on the track, but I've had a brake piston boot crack before on my E36 M3. The small parts of the piston started to rust and eventually stuck and braking became a nightmare (uneven brake bias between the two front brakes).
Just something I wouldn't do. I never go to the track unless my car was at 100% because small issues become more amplified at track speeds.
Old Feb 27, 2010 | 08:31 AM
Elistan's Avatar
Picture of the damage from the grit:
