Front lower control arm bushing failure
Old Apr 25, 2004 | 03:40 PM
  #21
TubeDriver's Avatar
Thanks for the heads up. I'll have to keep an eye on these. I assume you are running R-compounds? I'll add this to the arm frame mounts as things to keep a look out for.
Old Apr 25, 2004 | 04:18 PM
  #22
TrueDrezzer's Avatar
Took a look under my car and both LCAs look symmetrical to each other, with neither bushing non-centered or showing any other signs of damage. Hmm... any idea what else could be causing my toe to drift out so quickly?
A-arm brackets look fine, too. I only run street tyres with some Ferodo brake pads.
///Robin
Old May 7, 2004 | 03:57 PM
  #23
RandyP's Avatar
I just had to replace the driver's side LCA due to this bushing rubber problem. The rubber was badly torn on the inside rear, top and bottom. A smaller crack was starting on the upper front which was visible when the wheel was off. In my case, it was 40,000 miles, 4 years and many autocrosses.
Old May 7, 2004 | 04:02 PM
  #24
krazik's Avatar
Administrator
There will be an product soon from go fast lab, for the people not running in Stock class to address this.
Old May 7, 2004 | 04:57 PM
  #25
jerrypeterson's Avatar
Ummm... Hurry up and I promise to be a good customer.
Old May 1, 2005 | 03:59 PM
  #26
RandyP's Avatar
Passenger side LCA is now starting to tear at 50,000 miles, 5 years of autoX.
Old Feb 17, 2006 | 06:35 PM
  #27
rlaifatt's Avatar
So Ry, what ever came of this?
Old Feb 17, 2006 | 11:31 PM
  #28
CosmosMpower's Avatar
Wow great writeup, I was wondering if it was normal for my passenger side to get -1.3 camber and 6+ caster but my drivers side to only get max 5.5 caster with the camber at -1.3.
The bushing looked good at a quick glance but I may pull off the LCA and take a closer look. I know the more - camber you add the less adjustability in caster you have but I didn't understand why it was only happening on one side.
Old Feb 18, 2006 | 07:20 AM
  #29
cthree's Avatar
Administrator
A blast from the past.
Old Feb 18, 2006 | 08:40 AM
  #30
Asura's Avatar
