Front Sway Bar Options
Sorry I wasn't clear. I have a stock front sway bar but I dont have the endlinks. I don't want to buy stock front endlinks if I'm going to replace my stock front sway soon anyway and have to get new endlinks that fit the aftermarket bar.
So on that same token if an 01 with square tire setup using star specs or similar tire on Koni yellows, stock valving, and 550/480 springs to drive in hpdes what kind of sway bar is needed?
Diameter by year:
MY2000 Front 28.2MM T5.0 Rear 27.2MM T5.3
MY2002 Front 26.5MM T4.5 Rear 27.2MM T4.5
MY2004 Front 26.5MM T4.5 Rear 25.4MM T4.5
MY2006 Front 26.5MM T4.5 Rear 25.4MM T4.5
MY2008 Front 27.2mm Rear 25.4mm
CR2008 Front 28.6mm Rear 26.5mm
Eibach Front 32MM Hollow, Weight=10.6 lbs
Whiteline Front 30MM Solid, Weight=
Tanabe Front 30.4MM Hollow
Anyone have a link to a page that has the actual specs to the oem sway bars instead of the thickness levels? Searched high and low and I just can't seem to find it.
I also don't understand what you mean by "the numbers don't add up". Your post didn't list any calculated numbers, only measured ones.
Sorry to resurrect this thread, but I just got the Gendron bar 1.25" O.D. hollow bar with 0.25" wall thickness, and I can't find the stiffness settings anywhere. I did do a search. Can anyone point me in the right direction? Thanks
gendron 1.25" hollow setting 1 578/527/721
gendron 1.25" hollow setting 2 628/571/782
gendron 1.25" hollow setting 3 685/621/850
gendron 1.25" hollow setting 4 831/742/1016
gendron 1.25" hollow setting 5 917/817/1118
gendron 1.25" hollow setting 6 1016/904/1238
